Projects => Build Reports => Topic started by: Daza on August 26, 2022, 10:33:44 PM
Title: ManOWar - Maxon AD900
Post by: Daza on August 26, 2022, 10:33:44 PM
Hello! I've been using madbean pcbs for many years, this is my first time building a pedal and I'm so happy I have to show it off. In my country (Chile) it is very expensive and slow to bring components, so it took me time to put it together, it sounds great and the fact that it has tails is a great addition. I used bypass buffered.
(https://i.imgur.com/eCo6vQs.jpg)
Title: Re: ManOWar - Maxon AD900
Post by: jimilee on August 27, 2022, 01:02:14 AM
Mine must be defective, mine just makes me sound like a bass player trying to play guitar. Yours looks amazing.
Post by: gordo on August 27, 2022, 01:33:29 PM
Great build!  I'm with Jimi, mine doesn't have that many notes in it :-)
Excellent playing and demo.
Post by: Daza on August 28, 2022, 04:37:35 PM
Thanks for the feedback. It has problems with the impedance of the effects loop of my rectifier, it cuts the signal badly (in my 5150ii it works perfect), it is not the clipping of the mn3007 so I suspect the ne570, I ordered them from a Chinese seller through ebay, but I already bought some v571 from cabintech
Post by: nzCdog on August 30, 2022, 10:05:07 AM
Looks and sounds great :)
Post by: BryGuy on August 31, 2022, 11:04:51 PM
Nice build. Dig the purple.
Post by: blackhatboojum on August 31, 2022, 11:56:51 PM
Nice build.  The Man O' War is my favorite analog delay build thus far.  Personally, I think this delay works best running in front of your amp.  When you say "Rectifier effects loop", are you referring to a Mesa dual or triple rectifier amp?
Post by: Daza on September 02, 2022, 03:43:19 PM
Yes, I am referring to a mesa boogie dual rectifier MV. I have to lower the send level a bit and it doesn't saturate. I mainly play metal, it doesn't serve me to use it on the front
Post by: blackhatboojum on September 03, 2022, 12:06:58 AM
Quote from: Daza on September 02, 2022, 03:43:19 PM
Gotya.  Well, that's actually the nature of of a parallel effects loop.  You weren't experiencing an impedance mismatch it was more of a too hot of a signal scenario.  Lowering the send level is exactly what you need to do to keep the circuit from clipping.  The reason you don't experience the same thing with the Peavey is because it has an instrument level series loop.  As far as the man o' war out front... I too am a hard rock/metal player, with a cranked jcm 800 clone, with no effects loop, and it works great out in front.  That's actually why i like it so much.  It's more subdued and doesn't have the output like most delays, therefore works great in front of distortion.  Out of the countless delays I've tried, this circuit is the best one I've ever put in the front of my amp.  Give it shot, it might surprise you.
Post by: in8241 on September 04, 2022, 05:39:53 AM
Great pedal, great graphics, great playing! You nailed it!
