Here is the last build of 2022 for me. This is a continuation of my artist-pedalboard-in-a-box series. This time I put together a build based on David Gilmour's Dark Side of the Moon pedals.
For the majority of Dark Side tones, Gilmour used a combination of Fuzz Face, Overdriver, Uni-vibe and Echorec (along with a few more, but those are the bulk of tones). The pedal starts with a modified Silicon Fuzz Face (I used the Lunar Module as a base for the Fuzz). This moves into a Powerbooster circuit ran at +18V. Then it hits an effects loop if you want to add other pedals and then onto a Uni-Vibe circuit. This is the same Uni-Vibe I used on my Gypsy (https://www.madbeanpedals.com/forum/index.php?topic=34170.msg327607#msg327607) pedal. It sounds really good and vibe-y and the addition of being able to use an expression pedal really adds to its versatility. The Delay portion on this is a multi-head PT2399 delay I've been working on based on the Binson Echorec. Its taken a lot of inspiration from the Skidmark Sonomatic and DiabloChris's Sagan Delay. It has basic controls for Mix, Swell (Feedback) and Delay time, with 4 switches to select what heads are active. Unlike the Echorec with a max delay around 310-340ms, this goes up to about 800ms. Each head compounds into the other, so the ratio's of all delay heads are the same as a true Echorec. When you have multiple heads active, it creates a really cool sounding effect, something you don't hear anywhere else.
All in all, this is a really cool pedal. I'm really happy with how it turned out, and even if you aren't looking for Dark side tones, I think that it would be a very versatile grab-and-go pedal that would work in plenty of situations.
(https://schutone.com/wp-content/uploads/2023/01/Luna-Obscura_1.jpg)
(https://schutone.com/wp-content/uploads/2023/01/Luna-Obscura_2.jpg)
Crazy-cool, brother!
Quote from: Haberdasher on January 03, 2023, 03:27:17 PM
Just wow!
Amaze-balls! 8)
(https://i.imgur.com/WrKPhfd.gif)
This is looking super amazing! Nice job!
Was wondering, what is the vactrol for?
Quote from: Bio77 on January 04, 2023, 03:46:59 PM
The Vactrol is to convert the normal Dual Gang Speed pot to a Single Gang speed pot (which then can be wired to an expression pedal). I took the idea from Brian's Harbinger 2 and RG Keen's UVICS (Univibe in a Crybaby Shell) document.
Gotcha, thanks for the explanation. Killer build, dude 8)
In case anyone is interested, I've made up a demo of this guy.
