Gudday all, here's KTS, using Effectlayout's Kentauride pcb. It's a TS-10 into a Klon.
There's a post here somewhere from me where I've had all sorts of issues with the pcbs I got initially. One grounded the signal at the input, and the other two have a fairly low gain and volume on the TS side.
With this one, I looked up high gain mods and did a few component swaps and these brought it up to where I thought it should be. Then, somehow, I killed a trace so I had to jumper across to get the output. Anyway, it works now if a little messy and I'll socket those components in future builds (I have another 2 to build).
This was weird as the schematic and values are the same for any other TS.
I may or may not trim those leads to a shorter length.
Tayda drill and UV print, using stolen internet images from somewhere. I'll probably try and find aluminium red/green knobs for the next one.
This one got lost in the shuffle
How do you like the sound? I have the Loyalist and it's an interesting premise to have two well known circuits in parallel(?) like that. I find the Rat in that a bit overpowering.
Is there a decent balance between klone and Screamer?
I've built the Loyalist as well, wasn't bad actually but sold that off (they're in series, btw). I haven't played that much with this, I don't find either to overpower the other.
