Projects => General Questions => Topic started by: mitch66 on January 26, 2012, 08:14:23 PM
Title: Boneyard at +/-12V vs TC1044S spec
Post by: mitch66 on January 26, 2012, 08:14:23 PM
I would like to run my Boneyard at +/-12V
Datasheet shows that the rated operational voltage is  1.5 - 12 volts and absolute MAX voltage is just 13V.  That seems dangerously close to the rated operational voltage when running at +/-12V.
Has anyone had any trouble blowing up these TC1044s by using standard unregulated 12V wall warts which start off around 14V and drop down under load ?
Title: Re: Boneyard at +/-12V vs TC1044S spec
Post by: shawnee on January 26, 2012, 11:16:19 PM
I didn't have a problem with mine when I ran +12v into it. I would go for it (especially since the chip is only a buck).  If the  TC1044 dies (and I doubt that it will) you can alway replace it with the LT1054 (if you disconnect pin one).
Post by: madbean on January 27, 2012, 01:24:57 AM
The TC will handle the 12v, no problem. Just use a well regulated supply.
Even the MAX1044 handles 12v, according to frequencycentral. He uses them all the time in his tube pedal designs.
Post by: bs_ane on February 19, 2012, 08:54:53 PM
Max1044 is basic running with 9v????I want to build vineyard and I want to use it with 9v adapter
