Projects => General Questions => Topic started by: pigyboy on August 23, 2010, 12:31:22 PM
Title: Low Gain Fuzz Design to Share
Post by: pigyboy on August 23, 2010, 12:31:22 PM
Hi,
I have a new fuzz designed for low gain pnp germanium transistors. Kind of a combo of a Mosrite Fuzzrite and a Fulltone '69.  I found a supply of about 150 low gain very old germanium transistors that sound great in this design. I have it all done up on eagle and built several prototypes. It sounds fat and has very little background noise. I can post this if people are interested. Might be a fun project to get some people involved in.
Title: Re: Low Gain Fuzz Design to Share
Post by: Haberdasher on August 23, 2010, 01:35:31 PM
About how low is the gain (re: hfe) on your germaniums?
Post by: pigyboy on August 23, 2010, 06:02:24 PM
Hey,
The transistors I found are really low gain. 8-20 hfe.  They sound good though. Here is the Eagle schematic to mess around with. Nothing ground breaking but I am very please with how this circuit sounds.
[attachment deleted by admin]
Post by: oldhousescott on August 23, 2010, 06:10:29 PM
Can you print that to a PDF, or perhaps export to GIF? No Eagle here, not even the freebee one.
Post by: pigyboy on August 23, 2010, 06:34:42 PM
(http://i852.photobucket.com/albums/ab86/pigyboy_2009/Picture1-1.jpg)
Try this. I have found it very easy to use different transistors biasing them about 4.5 volts or so. Start with the 100k resistors go from there. Easy build. Good touch sensitivity and guitar volume control over the fuzz. The reason for C2 and C3 being so close in size but different was I used a wima cap for the .047 (C2) and also for C3 but when I popped in a ceramic .05 for C3 it opened the sound up to my ears. Just the cap type made quite a difference. Experiment around and see what you get. I built one with tropical fish caps and carbon resistors but the metal film resistors and the cap combo I mentioned before sounds much thicker and defined to me.
