Projects => How Do I? Beginner's Paradise. => Topic started by: Bret608 on April 12, 2012, 02:03:53 PM
Title: Drill hole size for 1/4" jacks
Post by: Bret608 on April 12, 2012, 02:03:53 PM
Hi everyone,
I have a question on drill hole size for 1/4" jacks. What's an ideal size hole for most jacks out there?
The reason I'm asking is that I just got my first drilled enclosure from PPP  (for my in-progress Pork Barrel). For reasons I can't quite recall, on the drilling template I provided them, I went with 11/32" for the hole size. I think I thought that's what I was seeing on the Pork Barrel drill template. Anyway, the hole will accomodate one type of jack I have, i.e. these cool-looking ones I got from LaceSensor in his holiday PIF. Some Neutriks I have don't quite fit though.
Is 3/8" a more standard size?
Thanks,
Bret
Title: Re: Drill hole size for 1/4" jacks
Post by: jkokura on April 12, 2012, 02:19:41 PM
Yes, I think I usually use 3/8".
Post by: Bret608 on April 12, 2012, 07:49:06 PM
Thanks! I appreciate the guidance as always.
Post by: bigmufffuzzwizz on April 28, 2012, 12:09:39 AM
Some parts will vary in size..3/8'' is general and all jacks should fit through. I've had some that are smaller so they won't hold tight in place..Those held really well with 11/32. So yes your right on your questions.
Post by: midwayfair on April 28, 2012, 12:33:44 AM
Standard metal jacks I use 3/8. I had to use something slightly larger for the low-profile plastic jacks that Bean suggests for the mini builds, but I can't remember what I used. It might have been 7/16.
Post by: DutchMF on April 28, 2012, 05:38:34 PM
I'll help out the metric people: 10 millimeters  ;)
Paul
Post by: alanp on April 28, 2012, 08:28:25 PM
Simple soul that I am, I eyeball which drill bit is closest.
The way to test it is to drill a hole in a spare bit of wood, and see if the component fits, and if the hole is too big or small.
Post by: DutchMF on April 28, 2012, 08:41:46 PM
I love to get these insights in how everybody has their own methods. I measure every part with a caliper micrometer.......  ::)
Post by: TNblueshawk on May 01, 2012, 02:35:01 PM
Quote from: DutchMF on April 28, 2012, 08:41:46 PM
Ha! Usually I'm that OCD but for some reason when I first started I used the unibit and just made sure I went slow and would dry fit it as I went. Now of course I pretty well have them all memorized.
The only issue is the DC jack. That one is so easy to screw up and overdrill it...at least with the uni's I have right now.
Post by: gtr2 on May 01, 2012, 05:29:39 PM
Measure once, drill twice.  :o
Post by: TNblueshawk on May 01, 2012, 06:08:18 PM
Quote from: gtr2 on May 01, 2012, 05:29:39 PM
I've been on the wrong end of that too many times  ::)Let's see. There is:
- Tile cutting. Screwed up that so many times I don't even get mad
- Hardwood flooring. I have even screwed up cutting the end piece where you have the bass mold and quarter round as an "error window"
- Building a hot tub house around my hot tub.
- Any and all wood work projects
- Etc...
Post by: DutchMF on May 01, 2012, 06:52:48 PM
Word! No, double Word!!!
