Projects => Tech Help - Projects Page => Topic started by: soonerrob on May 17, 2012, 12:47:33 AM
Title: Boneyard POP on Boost
Post by: soonerrob on May 17, 2012, 12:47:33 AM
Hey guys, just finished up my Boneyard build... everything seems to be working perfectly except that my Boost pops loudly when being both engaged and disengaged...
I installed the BOOST 3PDT switch under the 1590BB part of the docs.. I used a A100K pot with 22k resistors on the pot and the switch.
I installed the RPD @ 2.2M which did not remedy the issue.
This happens both in and out of the box... no part subs.
any clue what could be causing this?
Title: Re: Boneyard POP on Boost
Post by: k.rock! on June 14, 2012, 12:09:47 AM
Got the same issue and asked the same question over here, in case somebody answers over there:
http://www.madbeanpedals.com/forum/index.php?topic=5016.msg45181#msg45181
I'll post any solutions that work for me as well :)
-K
Post by: oldhousescott on June 14, 2012, 12:45:46 AM
Try reinstalling R9 with a value of 470k or 510k. Connect the switch leads to the R9 resistor legs.
Post by: Beedoola on July 18, 2012, 05:08:35 AM
Quote from: oldhousescott on June 14, 2012, 12:45:46 AM
Bumping this, I'm having the same issue.
Old; are you saying install a resistor back into PCb and have each respective wire also connect to the PCb with the resistor?
Post by: oldhousescott on July 18, 2012, 03:25:52 PM
Yes, have both a resistor in place and the wires going to the switch. When the switch is changing positions, there is a moment when there is no feedback around that opamp stage and it could conceivably cause the opamp to hit a PS rail. Installing a resistor in R9 will limit the max gain during the momentary state, but it has to be large enough to not greatly affect the two switch position values, hence the recommendation for ~500k.
Post by: Beedoola on July 19, 2012, 12:02:23 AM
I don't know if it makes much difference but I put a 470k across the middle lugs of the switch; the wires from these lugs go to the PCB; I was too lazy to take the pedal apart to put the resistor on the PCb. Seems to have solved the issue!
Thanks.
Post by: oldhousescott on July 20, 2012, 03:12:47 AM
Yes, that will do the same thing, and is a much easier way to implement the fix. Glad it worked for you.
Post by: altoaragon on February 26, 2014, 08:39:42 AM
I have the same problem....I try with the 470k resistor in R9 but the pop is still there.....Could you help me?
Thank you very much.
