So you can see the MKII I have been working on and has been the inspiration for this thread:
http://www.madbeanpedals.com/forum/index.php?topic=5623.0
Soundclip is in the Audio/Video demos:
http://www.madbeanpedals.com/forum/index.php?topic=6009.new#new
As you can see in the gutshot I bootstrapped a 33uf dry tant to the 47uf filter cap, ended up with a 10nf tropical fish cap for the output cap, and added a 47 ohm resistor between 9v+ and the board. Adding the 33uf and the resistor really helped cut down on background hiss that was there even with no trannies socketed, and i am really happy with the overall noise levels now. Also Attack pot is a 2k with a 2.7k resistor across lugs 1 and 3 that changes it to about a 1.3k pot which also helped Q3 from oscillating at high levels. Transistors are OC139 Q1, OC140 Q2, and OC141 Q3.
Catchy logo! Presence of Mustard cap is noted with approval 8)
Very cool!!!
Josh
