I am considering building a Bazz Fuzz/Rub-A-Dub combo box for a gift and have a few questions. This info will also help in future as I can foresee doing some other combo projects in the future.
1. Possible to power from a single 9v battery? (I don't use batteries but he does)
2. How to implement a switch or toggle to flip the order of the boards?
3. Possible to have footswitch(es) to control each and also both at once?
C
I'll jump in, but I'm sure others with a bit more info will chime in as well
1. yes, probably. the Bazz fuzz should be no problem since fuzzes and ODs generally don't use many mA. I don't know how much power the Rub-A-Dub uses...probably more than a PT2399 delay. That would be the deciding factor.
2. here's an idea http://www.geofex.com/Article_Folders/juggler/juggler.htm you can omit the LED and use a 3pdt toggle. you'd almost never want reverb first unless you're going for some zany sounds
3. There's probably a way. The simplest way would be to have two footswitches close enough together that you could step on both at the same time or either/or.
Also this is how everyone does the most common "two effects one box, two switches"
http://www.generalguitargadgets.com/pdf/two_in_one_wiring.pdf?phpMyAdmin=78482479fd7e7fc3768044a841b3e85a
Or you can use Madbean's standard wiring diagram: Input jack -> input lug of 1st switch -> output of 1st switch goes to input lug of 2nd switch->output jack etc
THANKS!
1. will investigate, might make it a Cave dweller/Bazz Fuss instead, will have to see
2. thx- my friend loves nutty sounds so might actually be good
3. DOH! ya, 1 foot, 2 switches, that will work
C
