Projects => General Questions => Topic started by: murdog47 on September 06, 2012, 03:18:51 PM
Title: Retrograde 1n34a's ??
Post by: murdog47 on September 06, 2012, 03:18:51 PM
So I built two retrogrades, one for myself and one for a friend.  As far as I can tell they are identical with the exception of the 1n34a diodes.  One has a very nice pronounced octave and the other does not.  Could this be caused by using different 1n34a's?
Title: Re: Retrograde 1n34a's ??
Post by: murdog47 on September 07, 2012, 05:01:31 AM
And voltages are almost identical on both.
Post by: Mike B. on September 07, 2012, 02:44:22 PM
Every Octavia I've ever built has a bit different level of octave mix. I attributed it to a combination of the inconsistent forward voltages of the diodes and transformer windings/core.
Post by: murdog47 on September 07, 2012, 03:01:21 PM
I stared at the circuit last night after work and realized my problem! I didn't use a switch so I needed to run a jumper to get the octave instead of just the fuzz. DOH! Sounds great now  ;D You are right though, there definitely is a difference in the octave between the two.
