Projects => Tech Help - Projects Page => Topic started by: lincolnic on November 20, 2010, 01:30:03 AM
Title: Krankosaurus C5 - 1 uF electrolytic or box?
Post by: lincolnic on November 20, 2010, 01:30:03 AM
Hey guys,
I'm building a Krankosaurus, and I only notice now that C5 (1 uF) is supposed to be an electrolytic. I was only able to find this value as a box cap from Small Bear. Can I use what I've got, or does it have to be electrolytic?
If it does have to be electrolytic, does anyone have two of them to spare? I'd be much happier sending you the dollar for postage than putting in an order just for two caps. Thanks!
Title: Re: Krankosaurus C5 - 1 uF electrolytic or box?
Post by: mjcyates on November 20, 2010, 02:18:42 AM
I have some extra 1uf electrolytics that I can spare.
Post by: oldhousescott on November 20, 2010, 04:58:47 AM
The box cap would work fine there, but you may have trouble fitting it in the board. If mjcyates or someone else will send you an electro cap, that will look and fit better.
Post by: lincolnic on November 20, 2010, 07:08:19 AM
Thanks guys. mjcyates, I've sent you a PM.
Post by: mjcyates on November 20, 2010, 01:10:00 PM
Quotemjcyates, I've sent you a PM
I just sent a reply. By the way does anyone in madbean land have 4 33n caps they could part with. I am making a Quasar and Gliteratti and mistakenly ordered 3.3n instead of 33n.
Post by: mjcyates on November 22, 2010, 04:17:50 PM
Your 1uf electros have been mailed.
Post by: lincolnic on November 22, 2010, 04:53:57 PM
Thanks again!
Post by: mjcyates on November 22, 2010, 06:39:11 PM
You are welcome. Good luck with the build.
Post by: madbean on November 22, 2010, 06:42:50 PM
Added note: you can almost always substitute non-polar film caps for electrolytics. Space and expense are the only deciding factors.
