Projects => Tech Help - Projects Page => Topic started by: ruffnick99 on September 28, 2012, 06:51:05 PM
Title: chunk chunk trimmers
Post by: ruffnick99 on September 28, 2012, 06:51:05 PM
I am building the chunk chunk project and this is the first pedal I have built with transistors and trimmers.
Here are the trimmers I purchased:
http://www.taydaelectronics.com/potentiometer-variable-resistors/trimmers/6mm-top-adjustment/100k-ohm-trimpot-variable-resistor-6mm.html
Are these the correct type I am suppose to use?  The leads are not even close to matching up on the board.
Title: Re: chunk chunk trimmers
Post by: jkokura on September 28, 2012, 07:00:51 PM
Nope, not the right type. They can be used, but as you mentioned, the lead spacing is wrong. You could use 3362 type trimmers instead if you can find some.
Post by: alanp on September 28, 2012, 07:26:10 PM
http://www.taydaelectronics.com/potentiometer-variable-resistors/cermet-potentiometers/3362p/100k-ohm-trimmer-potentiometer-cermet-1-turn-3362p.html
The 3362 trimmers are under cermet pots, for some reason. This is the type you want.
