I have a Pork Barrel chorus that I finished populating some time ago but never got around to housing, and I'd like to get it into a 1590B like the current layout uses by eliminating the mods (the Mix pot and the Vibe, Depth, and Wet switches). I know it will be tight squeeze as is, but the board itself fits so it's seems doable. Do I need to jumper any of these connections, or am I fine if I just disconnect them from the PCB?
Sure, just disconnect the Deep and Wet switches and jumper 3&2 of the MIX pads.
Quote from: madbean on October 08, 2012, 04:52:40 PM
Thanks Brian; same with the Vibe switch too?
Whoops..forgot. Jumper the Vibe pads.
Cool, thanks a bunch. :)
