Projects => General Questions => Topic started by: guile on November 10, 2012, 08:59:24 PM
Title: Questions about CAPS
Post by: guile on November 10, 2012, 08:59:24 PM
Hi electromagicians!
I want to build these pedals but the partslist is not clear about what type of cap to use.
Could someone specify (film, ceramic, silver mica, elco or tantalum)?
http://madbeanpedals.com/projects/Glitterrattii/docs/Glitterrattii.pdf
It's better specified here, but still not specified per part:
http://madbeanpedals.com/projects/Serendipity/docs/Serendipity_ver.5.pdf
♫Regards,
Gijs
Title: Re: Questions about CAPS
Post by: sgmezei on November 10, 2012, 09:49:44 PM
You can follow the same guidelines as the serenity doc. But in general:
For "pf" values you can use ceramic caps or multilayer ceramic caps
for "n" values I generally use film caps
for "uf" values I use electrolytic or tantalum caps
Remember to order at least 25v voltage rating to be safe. Anything above is fine but the physical size of the cap gets larger.
Also, when ordering remember the conversions that people use when talking about cap values
1000pf = 0.001n
0.01 = 10n
0.1 = 100n
Happy Building!
Post by: guile on November 10, 2012, 10:31:21 PM
Great!
Thanks. Learning every day.
Post by: DutchMF on November 11, 2012, 08:35:39 AM
C2 in the Glitterati is a 1uF film cap (which is pretty huge!). You could use electrolytic, bu then you'll have to watch the orientation!
Paul
