I'm planning on building an egodriver rated for 18V and a fatpants and was going to run them in the same pedal using the external 18v of the fatpants. I was planning on adding a couple of features but one of them would be a 3pdt switch to change pedal order (with LEDs).
Here is my question....
Would it be more worthwhile to build one dual pedal?
or three separate pedals?
- the ego driver
- the fatpants with 18v output jack to supply ego
- a pedal order switcher http://www.beavisaudio.com/projects/Looper-Switcher/Effect-Order-Switcher-Wiring-Diagram.png (http://www.beavisaudio.com/projects/Looper-Switcher/Effect-Order-Switcher-Wiring-Diagram.png) (with 4pdt)
Seems that the second option would cost more, but me much more versatile. Any thoughts?
I built one recently using a Quasar and a FatPants and I used a Rotary Switch to switch the order, also with a rotary switch, the pointer points towards whichever effect is first in the chain..
just keep building those pedals and give each one a "letter" for its name. daisy chain them all together to look like this
IN----M-A-D-B-E-A-N----OUT
then turn them all on at the same time ! ;D
I use this diagram, as it works on a toggle as well.
awesome thanks for that.
I always refer to the one by RDV posted at runoffgroove in the Double D project.
http://www.runoffgroove.com/dd-3pdt.png (http://www.runoffgroove.com/dd-3pdt.png)
flipper makes my head hurt !
but it looks very cool. i wonder if i should put it with my fuzz / phase :D
This is my take on switching the order of two FX in one box. PM me if you need further clarification
Paul
(Forgot to attach the file..... Sorry 'bout that. Damn, this weekend business is hard work!)
Quote from: DutchMF on December 02, 2012, 07:10:41 AM
Paul
Thanks Paul. I wasn't sure we're I got it from.
wow, a pain free diagram
Single sided etch using Dutch's diagram. Havent done it yet.
I upped it to 300 dpi, so I think its a 2:1 scale.
I'm just starting with eagle. 20mil traces. Untested. S1 = SEND 1, R1 = RETURN 1, ETC....
EDIT: forgot to turn off the linework for the switch, UPDATED
