What is the purpose of the 100R resistor in the Egodriver circuit at the power source? Why the voltage drop before pin 8?
Series resistance with a power source produces a low pass filter in combination with the filter cap which helps reduce noise, especially in higher gain circuits.
Interesting. Makes sense though. I noticed the quasar i just built didnt have it, so I was a little confused, but that would make sense, being that its low gain.
you can typically add a small resistance like that on pretty much any pedal, it's a useful strategy to help reduce noise.
