Projects => General Questions => Topic started by: Bman40 on January 04, 2013, 12:36:25 AM
Title: Road Rage for Mangler -reverse caps?
Post by: Bman40 on January 04, 2013, 12:36:25 AM
Hi all - I am hoping to start on a Mangler build soon, and have the parts on their way from Small Bear.
IF I use teh Raod Rage - do I need to reverse all the capacitors on the Mangler?
thanks
Title: Re: Road Rage for Mangler -reverse caps?
Post by: pryde on January 04, 2013, 03:22:09 AM
Not if you intend to build a PNP fuzz face. The roadrage will take you standard +9v (i.e. boss style adapter) and covert it to -9v to work with the PNP fuzz.
If you ordered NPN transistiors then you would flip the caps and protection diode and would not need a road rage at all going this route.
Post by: Bman40 on January 04, 2013, 04:22:16 PM
Pryde -
I ordered a set of PNP GE transistors from Small Bear for this pedal build.
I will build to standard spec and then use the road rage and my 1 Spot to power it.
thanks again.
Barry
