I just populated the pcb for a cupcake build and I realized that I used a 20k trimmer for the Sustain ... The build docs call for a 10k. My bad.... Can I leave it in there or should I replace it? I obviously don't have ones I used the 20 k. Will it still work???
Barry
You can use it, but it'll be a little hard to adjust perfectly. If you can wait, I'd pick up a 10K.
Or even better, use one of these, which will allow you to bias it perfectly:
http://www.taydaelectronics.com/10k-ohm-trimmer-potentiometer-cermet-25-turns-3296w.html
Thanks Jon
I'll see if I can find that ferment locally. I just did an order from Tayda and one part is too small an order.
I found pretty much the same trimmer at my parts source here in Vancouver.
Thanks for the tip.
Barry
