Does it matter which way i mount the DIP switches for the Aristocrat? Or are they simple toggles that can be installed either direction?
doesn't matter. they just on/off a connection.
I can't find info on the settings of the Aristocrat DIP switches as to which positions for clean, OD, distortion
Anyone?
I can't crack mine open right now but I believe it is like this:
both off = clean
one on one off = overdrive
both on = most gain available, I wouldn't call it distortion
Bump, can anyone verify or clear this up? I am waiting on an aristocrat and need to know how to set these dip switches. Its pre built, actually suppose to be built by Brian/MB himself as the prototype, so a solid explanation on how to set them is what setting etc.
Also if someone could just PM me the BOM that would be great.
Its as Gtr2 said above. And if for some reason yours isn't it becomes pretty obvious from the gain/volume you get as soon as you start moving them
That's not 100% accurate. Each dipswitch turns a pair of clipping diodes on or off. Dipswitch one controls the "overdrive" clipping diodes in the negative feedback loop, and dipswitch 2 controls the "distortion" clipping diodes that clip through an inline shunt. The "1: on, 2:off" setting is very different from the"1:off, 2:on" setting. The "both on" setting is just too subtractive and isn't really recommended. This information can be found in (a little bit) greater detail at the Analogman web site.
What mgwhit said, and down position is off.
Mine sounds decent with both dips up. I got an old prototype Madbean built. One side has a 4580, the other side has a 4588, they both sound different when set the same, its kind of interesting. Both sides are the same circuit right?
yes they are the same.
do you mean 4558?
Quote from: jkokura on April 03, 2012, 09:41:02 PM
do you mean 4558?
Yup ;D
