Projects => General Questions => Errata, Corrections, Revisions => Topic started by: madbean on February 02, 2013, 06:23:24 PM
Title: 02.02.2013 - Zero Point DD and SDX correction
Post by: madbean on February 02, 2013, 06:23:24 PM
In my haste to add every mod possible to these delays I added one twice without realizing it!
On the SDX - omit R45 the 1M resistor
On the DD - omit R30 the 1M resistor
This will increase delay times. You can still use the parallel resistors mentioned in the doc if you want to artificially reduce delay time but the two resistors above are superfluous.
Lastly, you can reduce R3 (in both builds) to 470k to reduce the dry volume path.
Title: Re: 02.02.2013 - Zero Point DD and SDX correction
Post by: madbean on February 02, 2013, 06:29:41 PM
Both pdf documents have been updated to reflect the changes.
