Projects => Tech Help - Projects Page => Topic started by: Stomptown on February 11, 2013, 07:02:43 AM
Title: tri color led/3p4t wiring HELP!!! ???
Post by: Stomptown on February 11, 2013, 07:02:43 AM
Hi everyone, I am trying to wire up tri-color led's to a 3p4t for a project and I think I know how to do it, but I was wondering if anyone knew how I would go about wiring TWO tri-color led's to the 3p4t (I want two leds so the drill layout is symmetrical. Anyway, here is a diagram I created after receiving advice on how to wire up one tri-color led. Any info on how to add a second would be great. Also, let me know if you see any issues with my diagram if possible. Thanks in advance...
Edit: my initial thought was to wire a second led using c,9,10, and 11 the same as I used b,5,7, and ? Is this right?
Cheers,
Jon W
(http://img46.imageshack.us/img46/182/tricolorledwiring.jpg) (http://imageshack.us/photo/my-images/46/tricolorledwiring.jpg/)
Title: Re: tri color led/3p4t wiring help
Post by: Stomptown on February 11, 2013, 03:34:30 PM
Bump...
Title: Re: tri color led/3p4t wiring HELP!!! ???
Post by: jkokura on February 11, 2013, 03:54:36 PM
If you want to add a second LED, you need to use another pole. Why not use the C pole? It's empty...
Post by: Stomptown on February 11, 2013, 06:20:55 PM
Quote from: jkokura on February 11, 2013, 03:54:36 PM
Cool! Thanks Jacob! I thought that was the way to do it but just figured I'd ask before I started soldering haphazardly. I should probably take the time to study up on switches and how they work...
