General => Open Discussion => Topic started by: wolfingsworth on February 16, 2013, 04:43:44 PM
Title: Cosmo board: Screwdriver or Lunar Module?
Post by: wolfingsworth on February 16, 2013, 04:43:44 PM
I etched up a board last night and am looking for some tips from somebody who has used both variations of the circuit. I heard there is info on the forum to change the cosmo into a Lunar module, can someone point me in the right direction?
Title: Re: Cosmo board: Screwdriver or Lunar Module?
Post by: juansolo on February 16, 2013, 05:00:14 PM
Didn't realise you could do that. Though IMO, the Screwdriver is the daddy of the two effects if you're choosing one or the other.
Post by: wolfingsworth on February 16, 2013, 07:52:43 PM
I did some digging and found it: http://www.madbeanpedals.com/forum/index.php?topic=2219.0
Quote from: juansolo on February 16, 2013, 05:00:14 PM
thanks for the feedback JS! I was kinda leaning that way.
Anyone else have an opinion? It seems like the biggest difference is the germanium and a variation on most of the cap values.
Post by: wolfingsworth on February 16, 2013, 07:59:15 PM
Dammit! This is starting to be a one sided converation... I found a thread from a couple years ago with this same question. http://www.madbeanpedals.com/forum/index.php?topic=1884.0
Hopefully this helps anyone else who was wondering.
Post by: JakeFuzz on February 16, 2013, 09:48:28 PM
I think it will depend on what you are looking for. The LM is very high gain and more aggressive sounding (but not much) than the SD. Personally I use my SD a lot more but I don't consider myself a high gain player. I find the LM gets a little dull when the gain is turned down so I like to crank the brightness knob or whatever it is called when I am using it as an overdrive. I would say if you are going for an all out, high gain, boosted fuzz face sound go for the LM. If a warmer "I wish my fuzz face face would do overdrive" sort of sound is what you want, I would go with the SD. Also note that the SD will change depending on the Ge you use. I like dark sounding NPNs with gains from 60-100 for that position but lower will work as well.
Post by: juansolo on February 16, 2013, 10:16:52 PM
The simple answer is to etch two boards and build both :)
Post by: wolfingsworth on February 17, 2013, 12:15:47 AM
Quote from: juansolo on February 16, 2013, 10:16:52 PM
this logic is sound.
