I finished up my HoneyDripper and noticed something strange.
Switch Positions 2 and 4 sound right. Position 4 has a little bit of squealing in the background, but positions 1 and 3 aren't getting any envelope applied. The sweep control does nothing, but the fuzz (clean) seems to work.
I'm checking the values on everything, but I just wanted to see if there was something stupidly obvious to check.
I don't have any spare CA3080Es to test but I tried swapping out all the other ICs to no avail.
As per the build instructions I changed the values on a few components:
C2: 680pf Ceramic disc
R5: 270K
R21: 2K
I took voltage readings of all the ICs as well:
ic4 jrc 4558
1 4.42
2 4.48
3 4.46
4 0
5 4.45
6 4.48
7 4.42
8 14.62
ic2 ca3080e
1 0
2 4.48
3 4.48
4 0
5 .032
6 4.48
7 14.55
8 0
ic3 ca3080e
1 0
2 4.48
3 4.48
4 0
5 0.424
6 4.47
7 14.52
8 0
ic5 lm324n
1 .426
2 .426
3 .426
4 14.4
5 4.28
6 4.48
7 .035
8 5
9 2.472
10 2.469
11 0
12 2.469
13 2.487
14 .032
ic1 lm324n
1 4.47
2 4.47
3 4.47
4 14.44
5 4.47
6 4.46
7 4.35
8 4.46
9 4.47
10 4.47
11 0
12 4.42
13 4.47
14 4.5
ic6 lt1054cp
1 1.363
2 4.01
3 0
4 .003
5 .174
6 2.532
7 1.392
8 8.05
Any help at all would be greatly appreciated. Thank you.
Have you made sure that the switch is working properly? Do you get continuity between A and 1, and also between B and 5 when you have it in position 1?
Quote from: trickpony on March 09, 2013, 01:40:37 AM
I do. I said I got effect in postions 2 and 4, that was reading left to right... actual switch positions that the effect works in are 1 and 3. 2 and 4 pass signal and the fuzz control works, but no envelope.
It wouldn't have surprised me if I had installed the switch incorrectly, but it seems to be correct. Thanks for the suggestion though :)
In position 1 I have continuity between:
A1 - A2 - B5
Position 2:
A1 - A2 - B6 - B8
Position 3:
A3 - A4 -B7
Position 4:
A3 - A4 - B6 - B8
Just another guess but pos 2 and 4 are both connecting to 6 and 8 from the schematic which just connects 10v through r25....are you sure r25 is ok? can you get an ohm reading of 2m2 between the 10v and switch pin6?
Quote from: trickpony on March 10, 2013, 06:35:36 AM
Sheesh.... It would appear I have installed a 2k2 instead of a 2M2 in R25.
I bet that has something to do with it.
Replacement of r25 with the correct value has really made a huge difference. I'm going to play with this some more and triple-check the values of my other resistors.
Thanks very much for the help.
Having same issue. Getting fuzz from one pot, but no effect from 4 way switch or sweep pot. Checked all resistor and cap values. Any have same experience ?
Also 3p4t switch is getting hot. Smells like burning, but no smoke or anything. Is this a bad switch?
ok solved it...switch is fine. I had IC5 in backwards so it was heating up and killing the effect. All good now. gonna change D3&D4 to 1n34a to try and get more effect, but sounds pretty good already.
