Projects => General Questions => Topic started by: Zerstorte Zelle on March 09, 2013, 04:29:47 PM
Title: Powering Multiple Pedals Same Enclosure
Post by: Zerstorte Zelle on March 09, 2013, 04:29:47 PM
Hey All,
I know there have been some recent multi-effect all in ones built and was just wondering how the powering is working out. I am thinking of building a 4 in one drive effect and just looking for any suggestions on the power. Do you think one 9v happily power a zombie / karate shop / slow loris / darkside? I'd love to keep the external power stuff to a minimum.
Best,
ZZ
Title: Re: Powering Multiple Pedals Same Enclosure
Post by: jkokura on March 09, 2013, 04:34:24 PM
Yes, if you power things in parallel.
But the key isn't whether you can wire them all to the same jack, the key is how much amperage they draw. In this case, it'd be the same as daisy chaining pedals, so as long as your power supply can handle the mA draw, you're good to go.
Post by: Zerstorte Zelle on March 09, 2013, 04:38:18 PM
so you'd suggest a higher ma 9v adapter? higher than 200ma? 500ma? i am also concerned with clean power and wonder if there is a better solution (simple) / other?
best,
ZZ
Post by: pickdropper on March 09, 2013, 04:58:28 PM
Jacob's response is spot on.  I'll just add that most OD/Distortion circuits don't draw a while lot of power, so 500mA should be more than enough for that.  Even 200mA should be fine, but I generally try and err on the side of too much if I don't know exactly what the circuit draws.
The One Spot power supplies can supply 1A, so that might be a good idea as it will give you flexibility to use it on something else later if you want.
Post by: Zerstorte Zelle on March 09, 2013, 05:34:19 PM
Thanks guys I'll have too look into it a bit more.
best,
ZZ
Post by: hammerheadmusicman on March 09, 2013, 06:10:04 PM
Surely if you have something like the OneSpot, that supposedly power up to 99 pedals, a 4 in 1 should be fine? Unlees you have the worlds biggest board!
Title: Re: Re: Powering Multiple Pedals Same Enclosure
Post by: jimilee on March 10, 2013, 04:16:55 AM
I was thinking about soldering all those wires on one little tiny dc jack. I was thinking about using some vero to assist with this. Any thoughts?
Post by: eldanko on March 10, 2013, 02:27:25 PM
Yep! I use little bits of stripboard myself. Works great.
Post by: pedalman on March 11, 2013, 04:41:08 AM
Quote from: hammerheadmusicman on March 09, 2013, 06:10:04 PM
LOL....were working on it !
Post by: hammerheadmusicman on March 11, 2013, 11:06:30 AM
Indeed we are!
Post by: Zerstorte Zelle on March 14, 2013, 04:44:10 PM
Quote from: eldanko on March 10, 2013, 02:27:25 PM
if i were splitting the 9v out 5 ways i could run each lug of the dc jack to the bits of vero and then split them there? thats a great idea
zz
Post by: juansolo on March 14, 2013, 09:11:05 PM
A note on mutli pedal enclosures. I've had issues with both the two I've made lately.
The Black Lagoon I transplanted the V3205 for an MN3005 and at first thought I could power both from the CE-2 charge pump... Nope, the power draw is too great, so I stuck a 2nd pump in there... Well that caused some interesting issues! Cleggy seems to think they're heterodyning. Took the one off the Aquaboy and ran that at 9v and the problem goes away. But an interesting issue!
In the other one the Apis and Fatpants pump were doing something similar though this time in the Fatpants sounding like it was buzzing. Bypassing the Fatpants pump (disconnecting the 9v line and running itto  the 18v feed skips it) makes it go away. Very odd.
I know it's not related, but I thought I'd put them up here anyhow for reference if anyone else has similar issues.
Post by: pedalman on March 15, 2013, 03:18:08 PM
lol, to mutch stress and a hemorrhoid appears
Post by: RobA on March 15, 2013, 07:30:24 PM
Quote from: juansolo on March 14, 2013, 09:11:05 PM
Which charge pumps were you using? Since the LT1054 can deliver 100mA, it seems it should be able to handle the current draw from the two pedals combined.
Post by: juansolo on March 15, 2013, 11:13:53 PM
Quote from: RobA on March 15, 2013, 07:30:24 PM
Yep, you'd think it would (as did we), but it didn't. Big voltage pull down on it too when both are connected.
Post by: RobA on March 16, 2013, 01:14:33 AM
Weird. It's the Aquaboy and the CE-2 you are running on the charge pump? I don't know the current draw on the Aquaboy, but I've read the CE-2 is about 10mA. The Aquaboy shouldn't be more than double that. The whole draw should be less than 30mA. So, you should have plenty of room left.
Could it be in your actual power supply? I was just converting my CE-2 build over to the MN3207 so I could lift the 3007 and put it in a Small Clone I just etched a board for. After I did the change, the pedal wouldn't work and I spent an entire morning testing and pulling parts and redoing things until I finally realized that it was my power brick. I think its buck converter croaked and now when it gets a bit over 10mA the voltage dumps on the 9V outputs to about 2.6V. It drove me nutty.
I've done one build where I put a Fuzz Face and Rangemaster both on one charge pump to generate the -9V. But, they are both really low draw circuits.
