Projects => Tech Help - Projects Page => Topic started by: jimilee on March 20, 2013, 05:31:33 PM
Title: Deprofundis no bypass
Post by: jimilee on March 20, 2013, 05:31:33 PM
So this is odd,my deprofundis delay pedal stopped working in bypass mode,but still works perfectly when the effect is active. I've rewired the switch completely,I have continuity on the switch between 1-2,4-5,7-8 in one "mode" and then 2-3,5-6,8-9 in another "mode" this is a weird problem to have I think. Could this be a bad switch? It worked great for a while,then stopped.
Title: Re: Deprofundis no bypass
Post by: midwayfair on March 20, 2013, 06:09:21 PM
Make sure the PCB out wire is hooked up correctly.
Post by: jimilee on March 21, 2013, 12:58:30 AM
Quote from: midwayfair on March 20, 2013, 06:09:21 PM
Thanks jon. How does the audio flow across the circuit in bypass mode? That is to say,what is the path the audio travels?
Post by: jimilee on March 21, 2013, 04:17:40 AM
Yep,that was it,bad solder joint on the stomp switch itself on the input side that jumps from 4 to 9. It's weird to me though that I had effect and no bypass.
Post by: jimilee on March 23, 2013, 04:42:46 AM
Holy crap, love this pedal!!!
