Projects => Tech Help - Projects Page => Topic started by: tuddy24 on March 28, 2013, 01:58:32 AM
Title: FatPants Pre-Build Checklist
Post by: tuddy24 on March 28, 2013, 01:58:32 AM
Hi All,
After much looking around I've decided to embark on a FatPants ed. 2012 build.  I've read the build doc and have a few questions about the parts.
1. Will box film caps from Mammoth fit in the signal cap locations?
2. Are > 36V rated filter caps good enough for the electrolytics near the charge pump?  Also, what's the general requirement for the voltage rating on electrolytics in the signal path?  I wish the build docs provided voltage ratings for caps!  Are the "audiophile grade" caps worth it?
I see the PCB will be available on 4-1, is it possible the layout or components will change?
-Pete
Title: Re: FatPants Pre-Build Checklist
Post by: Stomptown on March 28, 2013, 02:09:45 AM
The Fatpants being released at the Beginning of April is an updated 2013 version. I wouldn't order parts til the BOM comes out, or you find out what has changed...
