Projects => Tech Help - Projects Page => Topic started by: pierre67 on April 14, 2013, 04:54:30 PM
Title: Zero Point SDX help (please) SOLVED !!!
Post by: pierre67 on April 14, 2013, 04:54:30 PM
Hi !
I'm Pierre, this is my first post here...but I was reading around for a while...
Yesterday I build my first Zero Point SDX which worked right away; as I had a spare board and enough parts to build another one, today I decided to do it. The only thing different with this one is the caps, I wanted to try some Wima caps to see if they would make any difference in the sound. This one don't work  ???
The sound is gated and there is an aw full motorboarding noise...I can tell true the noise that control knobs do what they are suppose to do, as well for the switches...
I have done some voltage readings in the IC's if it can help :
IC1
1  4.77v    5  9.54
2  4.77      6  4.78
3  4.75      7  4.78
4  0.01      8  4.15
IC2 and IC3 same readings
1  5.02        9  2.52
2  2.5         10  2.52
3  0.01       11  2.52
4  0.01       12  2.52
5  1.28       13  2.52
6  2.45       14  2.52
7  0.28       15  2.52
8  0.80       16  2.52
IC 4
1  4.77        8  4.77
2  4.77        9  4.77
3  4.68       10  4.75
4  9.54       11  0
5  2.34       12  4.75
6  4.77       13  4.77
7  4.77       14  4.77
IC 5
1 between 2 and 5?
2 4.77
3  4.54
4   0
5  9.54
6  between 2 and 7 ?
7  4.54
8  3.97
Any toughs? :-[
Thank you !!!
Title: Re: Zero Point SDX help (please)
Post by: madbean on April 14, 2013, 04:59:22 PM
Voltages look good. Is the motorboating in all delay settings? What about if you turn the Mix knob all the way down?
Post by: pierre67 on April 14, 2013, 05:06:56 PM
Hi !!!
Yes, motorboarding in all settings. By the way the rate led works.
I allready checked for solder bridges, electrolytic caps orientation and everything seems fine...
Post by: madbean on April 14, 2013, 05:16:50 PM
Hmm. Next I would try removing some ICs and see if the motorboating goes away.
First remove the two PT2399s and listen to the dry signal. If you still have motorboating, removeIc5 (the modulation one).
This will help narrow down the area that is causing the problem.
You can also audio probe to see where the noise is coming from. Listen to pin1 on IC1A, pins 16 and 15 on both the PT2399s (with the ICs inserted back in).
Post by: pierre67 on April 14, 2013, 05:20:37 PM
sorry...i did not answer completely...With the Mix knob all the way down the noise disappears and my dry signal sounds fine...
Post by: pierre67 on April 14, 2013, 05:28:04 PM
update: the noise is gone when i remove IC 3
...audio probe..? :-[ way out of my skills  :P
Post by: pierre67 on April 15, 2013, 01:36:17 PM
me again...
Let me try to explain a little better the problem...With feedback knob all the way down I get 1 repeat that sounds very distorted and gated, sounds allmost farty. Delay pot does work, it delays the farty sound and mix pot does what it does, increases the level of the flatulence  :P...As i turn feedback up, that single farty repeat turns to a motorboarding sound...like a long fart...I can tell that modulation works to as I can hear that the noise (the farty sound) wobbles (and led indicator is blinking and varies as I turn up the rate pot).
Slam does work too.
As suggested, I removed one at the time ICs 5, 3 and 2. The noise stopped when I removed IC3...getting only dry signal.
I tried changing all ICs and transistors, change all caps around IC3, checking diodes and caps orientation, solder bridges...and nothing...Next step is, I guess,to remove pots to check if there is not something wrong under them (but I doubt it)...
With all this frustration I forgot to mention that the first one sounds awesome.
What should I check next?
In any case thank you for your help and your patience, I know is not easy to read such a complicated description from somebody that actually do not speaks English very well... :-[ (spell check does miracles)
Post by: madbean on April 15, 2013, 01:39:17 PM
I'm going to guess you have an incorrect resistor value somewhere, but I'm not positive yet that is the issue. Can we have a clear pic to the top side of your build, please? I'd like to see two close up shots: left side and right side. Particularly, let's look at those resistor values around IC3.
Post by: pierre67 on April 15, 2013, 01:51:48 PM
I'm taking a few pictues right now...i'll post'em in 5 min.
Thank you again !
Post by: pierre67 on April 15, 2013, 02:08:22 PM
I hope this will help...
(http://i1153.photobucket.com/albums/p508/patulo67/Fotos779_zps0fe3fb60.jpg) (http://s1153.photobucket.com/user/patulo67/media/Fotos779_zps0fe3fb60.jpg.html)
(http://i1153.photobucket.com/albums/p508/patulo67/Fotos780_zps8797ee9c.jpg) (http://s1153.photobucket.com/user/patulo67/media/Fotos780_zps8797ee9c.jpg.html)
(http://i1153.photobucket.com/albums/p508/patulo67/Fotos781_zpsa5855f7a.jpg) (http://s1153.photobucket.com/user/patulo67/media/Fotos781_zpsa5855f7a.jpg.html)
(http://i1153.photobucket.com/albums/p508/patulo67/Fotos782_zps99873a2a.jpg) (http://s1153.photobucket.com/user/patulo67/media/Fotos782_zps99873a2a.jpg.html)
C18 is a 2n2 Panasonic's cap (I did not have any more boxed ones)
C22 and C11 were changed to electrolytic
IC4 (removed) has a 16 pin socket which I put by mistake, so R28 is socket ed (removed in the picture)...
Post by: pierre67 on April 15, 2013, 02:33:42 PM
more pics, now with IC4 and R28 installed...(to many pictures? :-[ )
(http://i1153.photobucket.com/albums/p508/patulo67/Fotos792_zps3dd5670d.jpg) (http://s1153.photobucket.com/user/patulo67/media/Fotos792_zps3dd5670d.jpg.html)
(http://i1153.photobucket.com/albums/p508/patulo67/Fotos785_zps880dce19.jpg) (http://s1153.photobucket.com/user/patulo67/media/Fotos785_zps880dce19.jpg.html)
Post by: wgc on April 15, 2013, 03:38:39 PM
Is r45 supposed to be missing?
Post by: pierre67 on April 15, 2013, 04:04:32 PM
yes, r45 is omitted as noted in ZPSDX documentation update...
I'm checking resistors values one by one, but still not finding the source of this problem...
Post by: midwayfair on April 15, 2013, 04:27:41 PM
An audio probe is VERY easy to make and it would make it much easier and faster to track down the location of the problem. It's just a capacitor soldered to the tip wire of a cable, and then a wire to ground the sleeve. There are instructions to make on in the tech help rules thread.
Post by: gtr2 on April 15, 2013, 05:05:13 PM
http://diy-fever.com/misc/audio-probe/
Post by: madbean on April 15, 2013, 05:07:53 PM
Resistor values around the PT2399s look good from what I can see. I'll second Jon on the audio probe. It's going to be necessary in this case. Your voltages seem okay and your components appear alright (not that I've looked at every resistor value in your build).
You need to audio probe: R8, R9/R10 junction, R11/R12 junction and R21. Do this with the Ghost switch off and using the Feedback knob all the down and then a little bit up.
Post by: pierre67 on April 15, 2013, 05:36:25 PM
 :-[ sorry...I did not know what an audio probe was...all this years building effects, I guess I was just lucky...
Right now I'm reading RG's article on how to make (and use!) a probe.
I checked all resistors, nothing wrong here. I know that it is difficult to check a resistor value that's allready soldered in a circuit, but having another ZP working helped me to compare...I usually check all resistors with a multimeter before solder...the same with caps, so I was pretty sure that the problem wasn't there.
Post by: pierre67 on April 15, 2013, 05:42:44 PM
thanks for your replies, I will check with an audio probe as soon as I build one and learn how to use it...
Just one detail :I have soldered a on-off-on switch for  "ghost" ...but I guess that that is not the source of the problem.
Post by: pierre67 on April 15, 2013, 08:19:23 PM
So...
I put together a probe and I have done some testing...
With fdbk all the way down and delay and mix pot at noon, no ghost, mod and path engaged...
R8 : (C4 side) clean dry signal, (R41 side) mute
R21:(C29 side) Faint delay signal, (Out side) mute
R12: (C10 side) faint delay signal, (IC2 side) normal? Delay signal
R11: (C10 side) faint delay signal, (IC2 side) mute
R10: (C5 side) mute, (IC2 side) dry signal
R9: mute in both sides
R18: (C16 side) faint fuzzy signal, (IC3 side) distorted gated delay signal
R17: (R14 side) faint fuzzy signal, (IC3 side) muted (i guess, I forgot to note this one :-[)
R16 : (IC3 side) delay signal
R15: (IC3 side) mute
...sides are taken from the layout. Not sure if I'm doing this right, In any case I'll do some more testing tomorrow...
Thank you !
Post by: wgc on April 15, 2013, 09:55:11 PM
Quote from: pierre67 on April 15, 2013, 04:04:32 PM
It jumped out at me right away so I suspected it might be by intent, but figured i should mention it just in case..!
Those are nice pics btw... I'm sure you'll figure it out soon
Post by: madbean on April 15, 2013, 10:58:55 PM
The problem seems to center around R8/R41/R22/R9/R10.
Try this: remove both PT2399s again. Now audio probe pin 16 only of IC2. Do you get a strong clean signal there?
If so, can we see a pic of the bottom of the PCB on the area directly beneath IC2?
Post by: pierre67 on April 16, 2013, 01:31:43 PM
hi !
Removing both IC2 and IC3 I don't hear any signal at IC2 's pin 16...mute. With only IC2 removed I get clean signal in pin 16...
I don't know if this can help but I'm posting some pictures from the solder side...do I have to de-solder the delay pot to show a clearer view?
(http://i1153.photobucket.com/albums/p508/patulo67/Fotos798_zps4f6c99d3.jpg) (http://s1153.photobucket.com/user/patulo67/media/Fotos798_zps4f6c99d3.jpg.html)
(http://i1153.photobucket.com/albums/p508/patulo67/Fotos797_zps048bf1a5.jpg) (http://s1153.photobucket.com/user/patulo67/media/Fotos797_zps048bf1a5.jpg.html)
...looks messy but its only the flux...
Again, thank you for your patience...
Post by: madbean on April 16, 2013, 01:45:43 PM
Well, that's pretty bizarre. With IC2 removed you should get clean signal at pin16. You are getting that, so good. But, you said removing both IC2 and IC3 you get no signal at pin16 of IC2. Frankly, I don't know how that is possible. removing IC3 should not effect the path of the clean signal in any way.
I'll have to think so more about this.
Post by: pierre67 on April 16, 2013, 01:50:59 PM
I'll check again...
Post by: pierre67 on April 16, 2013, 01:55:02 PM
... :-[ sorry...with IC2 and IC3 both removed I get clean dry signal in IC2 pin 16...and mute in pin 16 IC3...In fact I get clean dry signal in IC2 pin 16 with or without IC3 installed
Post by: madbean on April 16, 2013, 02:29:51 PM
Okay, that's what I suspected. That's exactly how it should be.
Post by: pierre67 on April 16, 2013, 06:40:50 PM
I have done some more testing...change all ICs and transistors and the problem still there...
One thing that I've noticed is that the feedback pot goes from 1 dirty repeat when is full turned off to self feedback (I really don't know how to put it in words) when I turn it just a little (like at 9:00)...more exaggerated when ghost is on...I should post some sound samples but right now it's a little complicated...
Next thing I'll do is take off Delay and Fdbk pots to change some caps...I don't know, I'm lost here :-\
Post by: midwayfair on April 16, 2013, 06:47:29 PM
Quote from: pierre67 on April 16, 2013, 06:40:50 PM
I think you need to check that your feedback pot isn't a 1M ... is your modulation working properly?
Post by: pierre67 on April 16, 2013, 08:14:40 PM
...no, my fdbk pot is a 50Kb...and yes, modulation is working...rate led blinks and all... with the mod switch engaged  the distorted motorboarding noise gets some sort of modulation, that varies as I turn rate and depth pots...After checking all resistors values and looking for shorts and solder bridges I think I have 2 things left to check...all caps and diodes. I have changed some electrolytic and those 10µF tantalum, just to see if the problem was there, I guess I have to remove pots to test the rest of the caps...I don't know how to check for the diodes, they are all 1n914.
Right now I'm comparing values with diodes installed in the working ZPSDX...all of them are around 0.560v in my multimeter...don't see anything strange here...
Title: Re: Zero Point SDX help (please) SOLVED !!!
Post by: pierre67 on April 18, 2013, 04:34:20 PM
...et voilà !!! :D
Yesterday evening I took all pots off to see if I could find something and nothing...so I decided to desolder every electrolytic , diode, and check again all the rest of the caps...Today, after work I found the problem : I put a 10nF in place of a 100nF for C26... :-[
I feel super stupid and happy at the same time...It took me only 30 minutes to put all together...and voilà : my second Zero Point SDX works and sounds as good or better than the first one !!!
Thank you for your help,
Pierre
Post by: jimilee on April 18, 2013, 04:55:58 PM
Congrats! Debugging is part of the learning process I'm afraid! Feels good to get it running though, doesn't it?
Post by: pierre67 on April 18, 2013, 05:29:57 PM
thanks ! yes, it feels good !
What did I learn from this ? well...never build something difficult when my wife is talking to me...  :P
Post by: pierre67 on April 18, 2013, 05:56:56 PM
...and I learned what an audio probe is and how to use it !
I have to say that this boards are very good quality, I have soldered and desoldered and soldered back several components which can be tricky in a double sided PCB...
I guess I'll sleep peacefully tonight.
