Hello everybody !
...I was just about to put together a Green Bean when I realize that in the BOM the drive pot is 500k B, in most TS project that I build drive pot is 500k A...The same with the level pot which is 100k A when usually is a 100k B...Is it better this way? I'm a little confused here...
thanks !
Pot tapers are up to you. If you want to use another type, that's totally fine.
Tapers really are about how knobs respond. If you want to use a B or A taper, it will change the way the control interacts with the audible levels of gain and volume, but it won't hurt anything.
hey Jacob !
Thanks for your answer...I guess I'm going to build it with a 500kA and 100kB since I don't have any 500kB left.
