General => Open Discussion => Topic started by: brejna on May 11, 2013, 10:58:15 AM
Title: GGG Power Supply
Post by: brejna on May 11, 2013, 10:58:15 AM
Hi, is there anyone who had experience with this build?
http://www.generalguitargadgets.com/projects/24-power-supplies/23-four-output-isolated (http://www.generalguitargadgets.com/projects/24-power-supplies/23-four-output-isolated)
Title: Re:
Post by: ch1naski on May 11, 2013, 03:46:14 PM
It looks promising, especially considering how much a commercially available isolated supply costs.
Title: Re: GGG Power Supply
Post by: RobA on May 13, 2013, 11:35:12 PM
I've breadboarded this with the intention of building it. It works nicely. The only problem is that it won't fit in any of my normal effects size enclosures. The transformers are too tall. So, I'm looking for a new box that it'll fit in.
Post by: brejna on May 14, 2013, 06:19:02 PM
Thanks for responce, didi you  experience any noise?
Brane
Post by: RobA on May 14, 2013, 06:56:21 PM
It was cleaner than the commercial power bricks I have. It's going to depend mostly on what you do with the filtering caps. I felt that they were a bit under rated, so I increased the caps up to 470µF on the input side and then added a 100n after the 100µF on the output side. I used decent quality caps (Nichicon FW and Panasonic FR).
I didn't test it with a wide range of pedals though. I just tossed whatever was close by on it so that I could be sure that it was going to work. I'm still looking for a decent enclosure for it that can fit the transformers before I build it though. I may just build a pedalboard and mount it directly in the thing.
One thing to note is that I was going to do two 18V and two 9V outputs. It's the transformer for the 18V pair that is too big. I think that you could fit the transformers for the 9V outputs into a 125B box pretty well.
Post by: brejna on May 14, 2013, 09:41:06 PM
Wow!! It's nice to hear that it works very clean.
I am planing to make multipedal with just one 230V power cord going from pedal and I want to put power supply board  inside of  the pedal. Of course I attend to spllit comp/drive effects and modulations/delay.
Title: Re: Re: GGG Power Supply
Post by: ch1naski on May 15, 2013, 04:14:48 AM
Maybe the 18V transformers would fit in   1590bb tall box....
Two 9 and two 18V is exactly what I plan on also. One side to power a forum vibe build, the other for whatever.
Post by: brejna on May 15, 2013, 08:03:41 AM
Maybe it is possible, I've read datasheets for these two transformers :
http://www.banzaimusic.com/Hahn-BVEI3032036.html (http://www.banzaimusic.com/Hahn-BVEI3032036.html)
http://www.banzaimusic.com/Hahn-BVEI3052058.html (http://www.banzaimusic.com/Hahn-BVEI3052058.html)
and they are 2,4 cm or 0,94 in high, so it is possible to put them in the 1590BB but it will be very tight.
Inside dimensions of 1590BB is 2,8cm so it is bit tricky, the most important thing are Hex Standoff spacer 'cause they will carry thr whole pcb... or do you have another solution for that?
Post by: RobA on May 15, 2013, 07:02:36 PM
I've got the transformers that are listed in the webpage, the Triad 553-FS36-65 and there is no way it'll fit in a 1590BB with the PCB and standoffs. It won't fit in a 125B (although it is very close and it might be possible to get the 125B to work with careful arrangement).
It would work in something like the 1590S. But, I don't have any of those to test for sure.
If the transformers you are looking at are just a little bit smaller than the ones I have, it could be doable in the 1590BB, but I think it's going to be very tight.
Title: Re:
Post by: ch1naski on May 17, 2013, 02:24:25 PM
On the GGG page, it says it was built into a 1590S, with stand offs.
