Projects => Tech Help - Projects Page => Topic started by: midwayfair on May 23, 2013, 03:24:21 AM
Title: Aquaboy -- every problem imaginable
Post by: midwayfair on May 23, 2013, 03:24:21 AM
Oh lordy. I'm not sure this is really a tech help thread or an opportunity to laugh at me ...
1. Modulation isn't modulating -- the LFO isn't functioning. Somehow I have 15v on pins 1 and 5 .... even though pins 2, 3, etc don't have voltages that high. The chip is socketted and I tried another. No weird continuity or anything.
2. Delay is extremely distorted at pin 3 of the BBD and extremely low level. The bias range where I get any sound at all is very, very tiny. That part might be normal I guess ...
3. Signal is further attenuated at pin 3 of IC 4, and even more distorted.
4. My clock has to be dialed almost all the way CCW to get any signal on pin 3. Hallway is very loud clock noise and no audio. Since the biasing instructions have the clock STARTING at halfway, I'm assuming this isn't normal.
5. I have good signal from the compander going into pin 2 of the BBD, and I have the distorted repeats with almost no delay going into the post-bbd buffers, and I have signal when it hits the compander -- but then the signal completely disappears at pins 10 and 11. 100% dead on those pins.
Using 3005s tested by Gtr2 as genuine ... And the accompanying parts.
This is so many problems I don't even know which to start with. :(
Voltages:
-IC1 is correct and working.
-Compander:
1 - 1v
2 - 1.8v
3 - 1.8v
4 - Ground
5 - 1.8v
6 - 1.8v
7 - 3.1v
8 - 1.8v
9 - 1.8v
10 - 4.6 (?)
11 - 4.6 (?)
12 - 1.8v
13 - 15v supply
14 - 1.8v
15 - 1.8v
16 - 1v
Clock
1 - 13.3v
2 - 6.6v
3 - Ground
4 - 6.6v
5 - 6v
6 - 6.6v
7 - 6.4v
8 - 12.6
BBD chips:
IC3
1 - 13.3v
2 - 6.6v
3 - 9.7v
4 - 9.7v
5 - Ground
6 - 6.6v
7 - 4.5v
8 - 12.6v
IC4 - Same except
3 - 9.2v
4 - 9.4v
7 - 3.9v
IC 6
1 - 14.25v
2 - 1.3v
3 - 8.6
4 - ground
5 - 14.1 (not identical to 1 in any switch position)
6 - 9
7 - 9
8 - 15v
Delay lug 1 - 2.9v
Anode of
Top-side picture:
(https://dl.dropboxusercontent.com/u/9878279/Aquaboy%20troubleshoot.JPG)
Title: Re: Aquaboy -- every problem imaginable
Post by: gitaar0 on May 23, 2013, 08:47:45 AM
Hi Jon,
Just some suggestions and questions to have a starting point:
The lfo can be viewed as a separate problem for now.
If you have a distorted signal at pin 3 on bbd 1 then you are bound to have an even more distorted signal on pin 3 of the secon bbd. So let's get he first one right first.
If you have a clean signal going in bbd 1 then you shpuld be able to bias it with a reasonable clean signal at pin3 of bbd 1 when the clock is working ok.
If you have to dial the clock ccw to get signal then there should be someting wrong there.
What clock chip are you using? It should be the mn3101 when on 15 volt.
I would check all the components around the clock and my soldering there. What are your voltages on the clock Ic?
Maybe it helps for a start.
Marc
Post by: Scruffie on May 23, 2013, 10:20:24 AM
Quote from: midwayfair on May 23, 2013, 03:24:21 AM
Right... i'm assuming this is the DX project?
A full list of voltages is going to help here as always.
A few things gitaar0 has already covered here so forgive for the repeating.
1) While gitaar0 is right about it being a separate issue, let's look at it anyway. Pins 1 & 5, what is connected to them in any way, R45-47 & C34 & 35 and the Rate Pot, assuming you have 7.5Vish on Pin 3, the LFO V.Ref is working so we can ignore R43&44 and one of those components I mentioned is probably shorted or has a solder hair connecting it to a 15V point, a re-flow of the area might be all that's needed.
(I'd look closely at R43, the voltage input to the V.Ref is at the top of it and it's right next to R45, 46 & Pin 1)
2) Bias range should be... a rough estimate 1/8th to 1/10th of the entire rotation of the trim should provide some delay. You say the output is distorted and quiet, what's the signal like on Pin 7, clean and present like you'd expect? As gitaar0 mentioned again, the next BBD is working with a crappy signal so it's gunna put out an even worse one, focus on getting the first BBD to delay properly first. Voltages for this BBD might make an issue clear. A poor clock signal will result in a poor BBD output, the other option is something is wrong with the source follower.
3) See above.
4) It does sound like your clock isn't working right, it shouldn't need to be dialled to long delay times just to hear delay, seems it's not putting out a proper pulse. Voltages! Also where was it sourced from and did you take ESD precautions when handling it (CMOS so it's static sensitive). It's not a sure check but you should expect to see half supplyish on pins 2 & 4 and they should both be the same voltage.
5) Get output from the BBDs first before you trace further down the line.
Post by: midwayfair on May 23, 2013, 11:43:25 AM
Thanks guys. I'll go over it this weekend and give it a reflow as well and then take voltages.
Clock is 3101 and the compander is a 570, both from smallbear.
EDIT: Since there's no signal at pins 10 and 11 of the compander (and correspondingly on the mix and feedback pots), am I likely to need a new compander as well? I mean, I should still have the same signal that went in at pins 15 and 16, right?  :-\
Post by: juansolo on May 23, 2013, 05:27:00 PM
It's REALLY easy to pop the compander when messing around with this circuit. I think I've killed at least 3.
Post by: madbean on May 23, 2013, 05:40:12 PM
Try lowering or removing R37, Jon. See if that fixes the output on pins 10/11.
Post by: midwayfair on May 23, 2013, 05:49:45 PM
Quote from: juansolo on May 23, 2013, 05:27:00 PM
fuuuuuuuuuuuuuuuuuuuuu
Blowing $5 chips is not my idea of fun.
Brian, thanks for the tip, I'll try that, too.
Post by: gtr2 on May 23, 2013, 05:52:40 PM
If you need a compander, I believe I have a one that I'm not using anytime soon.  You know where to find me..
Post by: midwayfair on May 23, 2013, 05:53:36 PM
Quote from: gtr2 on May 23, 2013, 05:52:40 PM
Thanks, Josh, but I need other stuff from Smallbear, and you already did me a big solid testing the BBD chips to put my mind at rest about THAT particular question. :)
Post by: midwayfair on May 26, 2013, 04:48:03 PM
Updated the first post with voltages and a top-side picture.
The LFO still has me mystified. Everything checks out according to the multimeter; it's just not functioning.
Post by: midwayfair on May 26, 2013, 04:59:47 PM
Doh. I just saw that I need to omit R55 and R27. Will report back in a moment.
Edit: no meaningful changes.
Post by: gitaar0 on May 26, 2013, 08:43:45 PM
Hi Jon,
I am not at home so i can not compare all voltages. Just a few things for now:
D3 should be left out if you are using mn3005's at 15 volt.
Your power supply voltage at ic 3 and 4 is too low. (i forgot which pin) It should be around 15 volt.
Check my thread on the compander voltages that should be half the powersupply to get the best signal. Yours are off too.
Scruffie pointed that out to me.
Post by: midwayfair on May 26, 2013, 09:04:05 PM
Quote from: gitaar0 on May 26, 2013, 08:43:45 PM
Hi Jon,
This is partly my carelessness for sure. I made a note about your thread weeks ago and completely forgot. I'll make a few more changes, pull D3, etc.
Post by: midwayfair on May 27, 2013, 07:50:30 PM
Well, if the compander wasn't dead before, it is now ...
I pulled D3, changed R13 & 14 (sockets), and removed R37 (also sockets). The clock chip still whines above about a 1/4 turn, and now there's no signal after the input at the cmpander. I'm going to get new chips before I give up on this.
I've tried everything I can think of on the modulation circuit, too. I'm baffled and I've built this sort of modulator a dozen times and never had it not fire.
Post by: gitaar0 on May 27, 2013, 09:01:54 PM
Do not give up on this. It is a great build when it works. ;)
Considering what I have seen of your builds you should be able to ge this working.
Sorry that I can not be f help from where I am now. Maybe later.
Do not give up! ;)
Post by: aballen on May 30, 2013, 07:11:12 PM
Jon is it possible your trimmers are binding?  It looks like you had to bend the legs in to mount them.  I would check each one to be sure.
Post by: midwayfair on May 30, 2013, 07:33:19 PM
Quote from: aballen on May 30, 2013, 07:11:12 PM
Nope, they're working, but the clock is clearly not working properly.
I bend just the wiper leg -- that's the one with the big screw part in the middle, so that it if something DOES touch the body of the trim, the leg will just touch itself.
Post by: aballen on May 30, 2013, 07:55:22 PM
Just did a stare and compare, I found some issues but it looks like you removed the diodes and took care of the jumpers.
Not sure but it looks like R58 is a bit tight around the +/- joints.
hopefully the new compander takes care of your problem.
Post by: aballen on June 08, 2013, 01:11:22 AM
Any luck here Jon?
Post by: midwayfair on July 03, 2013, 02:57:34 AM
I *STILL* can't get the LFO working. I've verified every part multiple times and tested continuity to every other pad on the board. It just won't oscillate. It kills LEDs, too. It's blown two of them now. I'm completely mystified as I've never had an issue with this LFO (this is like the fourth delay with it I've built!).
At this point, I don't even care about the rest of the pedal. I just want to know why the LFO won't work. I even tried running it on 9v to see if for some reason the 15V was the problem.
Post by: RobA on July 03, 2013, 04:23:09 AM
I can't tell for sure from the image, but is the LFO IC a TL052? If so, the 052 is more prone to latching up than others in the same family.
Post by: midwayfair on July 03, 2013, 11:42:26 AM
Quote from: RobA on July 03, 2013, 04:23:09 AM
It's a 62. I've also tried a 72, 4558, 5532, etc. All of them should work just fine ... They do in every other pedal I've made with this LFO.
Title: Re:
Post by: aballen on July 03, 2013, 12:27:54 PM
It's not likely, but there is always the possibility the board has a short.
It's. really a great delay, might be worth getting a new board and re-using the active components.
Post by: RobA on July 03, 2013, 12:39:08 PM
Quote from: midwayfair on July 03, 2013, 11:42:26 AM
Yeah, they should all work, but I was wondering because the voltage readings on that IC look like it may be latched high. If you have a TS922 or can get one easily, you might want to try it. They can go rail-to-rail on both the input and the output in a single supply setting and never latch up. The other one that might help figure it out is the LM358 (if you haven't tried it already). They don't have the upper voltage output, but they won't latch when going to the negative rail and in several LFO's I've played with, when the op amp latches up from hitting the negative rail, it flips high and sticks.
