Projects => Tech Help - Projects Page => Topic started by: billstein on May 25, 2013, 11:16:36 PM
Title: Mulitplex Jr with Taptation
Post by: billstein on May 25, 2013, 11:16:36 PM
Building a Multiplex Jr. with taptation and have a couple questions before I get to far into this.
Here's what I believe I need to do.
1.  Put a Jumper for R25.
2.  Connect the taptation to lug 1 of the depth pot.
3.  Don't use the time pot on the Multiplex Jr. What do I do with the pads on the MP board for the time pot? Leave them alone? Jump them?
4.  There are 3 Led's between the two boards. Modulation rate on the MP jr. Clock and Scale on the Taptation. Do I use all of them?
5.  I'm assuming the dot on the vactrol solders into the square pad on the MP jr board. Is this correct?
Thanks guys for your help.
Bill
Title: Re: Mulitplex Jr with Taptation
Post by: jkokura on May 26, 2013, 04:22:32 PM
First off, I don't think this is a confirmed process yet - I haven't seen a Multiplex Jr with a taptation.
Second, many have had issues with trying to get the onboard modulation of things like the echo base to work with the taptation. Part of the issue is that both the mod and the tap tempo require access to pin 6, but they may not play well together.
In general, when you're applying modulation to a circuit and running a taptation, I recommend using  a modulating taptation setup because it allows you to include modulation. You will however lose whichever modulation circuit is onboard the PCB you're building.
Post by: dondougie on May 26, 2013, 05:07:37 PM
I built one just like that and it works fine with the modulation of the MP Jr. Yes, jumper r25 and connect the taptation to the depth pot. You can leave the time pot pads as they are, no need to jumper anything.
As far as the leds are concerned, it is up to you and how many blinking lights you like in your build :) I left the mod rate led on-board inside the case and used only the scale led of the taptation board to see the actual repeat tempo. No clue about the dot on the vactrol though.
Post by: jkokura on May 26, 2013, 05:26:09 PM
Quote from: DonDougie on May 26, 2013, 05:07:37 PM
Sweet! I'm really glad to hear that this works. Build report?
Post by: dondougie on May 26, 2013, 06:34:55 PM
Quote from: jkokura on May 26, 2013, 05:26:09 PM
I did one a few weeks ago at the 1776 forum ;) http://www.madbeanpedals.com/forum/index.php?topic=9373.0
Post by: gtr2 on May 26, 2013, 09:21:53 PM
The dot is the anode, so it goes to the square pad  :)
Josh
Post by: billstein on May 26, 2013, 09:45:47 PM
Thanks everybody.
