Hey all!
Ok, so first time with the taptation chipset. I'm feeding into a de profundis, and it sounds great. The ony problem I get is tapping is somewhat funky... If I take too long to tap, it switches into basically 0ms delay (scale LED goes solid). Overall tapping seems a bit hit and miss. Is that normal for this thing? I've tried 3 different taptation chips, 3 different digital pots, and 3 different pt2399's. Same result with all. When I do get a good tap, the PT2399 is really close to the lighted tempo.
Help!
Thanks,
TOdd
Did you try different switches? Usually a "too long" tap will come out as zero, but "funky" tapping implicates the switch. Only thing you haven't subbed....
