Hi all,
Just a thought ...
Could madbeanpedals make tiny smd pedals to fit inside the 1590LB enclosures available from places such as:
http://pedalpartsaustralia.com/index.php?main_page=product_info&products_id=125
Cheers
Joshua
what would you like to see done?
Quote from: muddyfox on September 17, 2014, 03:15:06 PM
Something like a Phase 45 or a Phase 90, basically any one knob phaser
pickdropper has 1590A sized Phase 90s for sale (and not SMT, cause deep down, he knows that SMT is the tool of the devil)
http://www.madbeanpedals.com/forum/index.php?topic=17471.0
Maybe, but where do you think those chocolates with whisky inside come from? SMD has it's place... well, the bigger size SMD does, SOD123 size SMD can get bent.
I'm actually into this idea. I think I will try to come up with one or two. That said, I think a phaser would be a bit of a challenge. But, we like challenges here.
building a bazzfuss into a 1590LB just about gave me a migraine...
so hell yeah I'd do it again 8)
off topics but, why some people call SMT????, i thought i was superfice mount devices(SMD), but im not expert, not trying to correct just, think that some has something that i dont know to call them that way
I wndered the same thing a while back. IIRC, SMT stands for surface mount technology. Some folks use one term and some use the other.
Already did a few. :) But not all of them work yet. :(. Stay tuned.
They are definitely fun, and I would almost definitely buy a madbean 1590lb pcb.
SMT is surface mount technology. Smd is surface mount device. A bit like squares are rectangles, but rectangles are not squares. People use them interchangeably.
I might think about a deluxe memory man. ;)
Quote from: Stomptown on October 03, 2014, 06:34:01 PM
Right. The correct usage depends on context. You do something in SMT with SMD. See http://en.wikipedia.org/wiki/Surface-mount_technology
Here's the the first try on an LB layout. I'm sure you can guess what it is. This one was for practice, but maybe I'll make a couple.
man you are really cool, may be a fuzz face??
Our FuzzIon wich is a simplified BazzFuss would fit in that quite easy, one knober, mounts on the 3PDT, components face down... enclosed jacks and there you go!
Quote from: madbean on October 05, 2014, 03:21:42 PM
Looks cool. Where do the Input / Output jacks go?
Quote from: pickdropper on October 05, 2014, 04:17:26 PM
The small ones will fit on the sides, I think and the PCB on top. However, after some more thought this type of layout might be better. Gives more room for the jacks. The pots could go on top or the sides. The DC jack would actually go on the top corner!
I suppose it's time for me to spill the beans a bit about how I do the Small Block. The most critical thing about building in the 1590lb is getting everything aligned. It's less space to work in than the 1590a. The other pedals I do, I mark, punch, and drill by hand. The Small Block I use a jig and drill press to get everything right, and I still need to tweak it a bit.
I use the space in the front of the enclosure, between the two screw bosses, to squeeze my board and I have it mounted vertically, hanging from a 9mm pot. I used to use a 16mm pot and had the boards free floating in that same space, enclosed in a length of 1" clear heat shrink tube.
I have the knob up on the face of the pedal, and I set the stomp switch has high as I can get it, which is pretty effective in protecting the knob from being inadvertently turned when the switch is stomped. It works great. I've had success building a two-knob circuit using 16mm pots, again with knobs on the face of the pedal. It was an electra distortion variant with an input volume added.
Using SMT would certainly make fitting everything easier, and mounting the pots on the front of the enclosure, like Brian has done, would open up some options and would offer better protection from accidental knob movement.
Here is what the Small Block looks like on the outside:
(http://i746.photobucket.com/albums/xx105/leevibe1/Small%20Block/image_zps9fb48718.jpg) (http://s746.photobucket.com/user/leevibe1/media/Small%20Block/image_zps9fb48718.jpg.html)
(http://i746.photobucket.com/albums/xx105/leevibe1/Small%20Block/image_zpsbfee2dac.jpg) (http://s746.photobucket.com/user/leevibe1/media/Small%20Block/image_zpsbfee2dac.jpg.html)
and the guts...
(http://i746.photobucket.com/albums/xx105/leevibe1/Small%20Block/IMG_3628_zps849edbaf.jpg) (http://s746.photobucket.com/user/leevibe1/media/Small%20Block/IMG_3628_zps849edbaf.jpg.html)
No, the jacks aren't touching. I don't know if enclosed jacks could work in there. They need to be able to bypass each other and I don't see it with a 3pdt sharing space. I'm thinking I need to try some kobiconns and a lumberg. Another way to save space would be to use an "outy" power jack. I'm just not crazy about the way they look.
Either way, building in these isn't for the faint of heart. :)
a few more pics...
(http://i746.photobucket.com/albums/xx105/leevibe1/Small%20Block/IMG_3623_zps959941b4.jpg) (http://s746.photobucket.com/user/leevibe1/media/Small%20Block/IMG_3623_zps959941b4.jpg.html)
(http://i746.photobucket.com/albums/xx105/leevibe1/Small%20Block/IMG_3624_zps3e759be5.jpg) (http://s746.photobucket.com/user/leevibe1/media/Small%20Block/IMG_3624_zps3e759be5.jpg.html)
(http://i746.photobucket.com/albums/xx105/leevibe1/Small%20Block/IMG_3625_zpsa018ee27.jpg) (http://s746.photobucket.com/user/leevibe1/media/Small%20Block/IMG_3625_zpsa018ee27.jpg.html)
Quote from: Leevibe on October 05, 2014, 04:51:18 PM
and the guts...
a few more pics...
Looks pretty spacious in there! ;D Seriously though, that looks great inside and out and it looks as trusworthy as any open from 1590A build I've seen! Do you overdrill the jack holes to give yourself a little more wiggle room or does the Jig get you close enough?
Quote from: Stomptown on October 05, 2014, 05:11:01 PM
I usually over drill the output jack a bit because sometimes it fights with the LED bezel. Once I get through this batch that is already drilled, I will probably go away from the big chrome bezels. They're a pain and they take up too much space.
I'll have to send you a couple of the Kobicon jacks to try out in there as well. You will be shocked how compact they are. They are really nice too!
Quote from: Stomptown on October 05, 2014, 05:24:35 PM
Wow, thanks Jon! I'll take 'em!!
Brian, that's some weird smd. ;)
Lee, amazing use of space!
I like the kobicons a lot but they can bend easily and not retain the plug.
Before I got the idea to omit the jacks, I was looking at enclosed jacks that are narrow but they are a bit longer at the thread. I will try to post a pic.
Quote from: madbean on October 05, 2014, 04:24:04 PM
Really dig that orientation, would make a nice pedal board by having couple of them all inter-locking.
@Leevibe, that's crazy... a while ago i though i was nutz for making a 3in1 1590A or use 4x 16mm pots in 1590A aswell... but you win....! :o
That boost is nucking futs. 8)
Oh, this is just bulls**t.
125b is about as small as I ever want to go, forget about SMD or whatever... On the upside, imagine how many effects you can fit onto a pedalboard with those things.
Here's the jacks I mentioned earlier. Not sure how durable they are.
http://www.allelectronics.com/make-a-store/item/phjs-4/stereo-1/4-phone-jack/1.html
I ran into these yesterday... crazy stuff.
http://www.mooeraudio.com/en/Product.asp?PClassID=36
Quote from: GrindCustoms on October 05, 2014, 09:17:31 PM
+1 on what Rej said. A Zig-Zag alignment would be awesome. Don't know about the DC jack in the corner though. Sounds hard to drill...
