General => Open Discussion => Topic started by: pogart on February 10, 2015, 10:33:49 PM
Title: Low Voltage reading on Mutiplex build
Post by: pogart on February 10, 2015, 10:33:49 PM
I've been reading through the posts on voltage readings etc for the multiplex from 1776 but did not find one that sort of addresses my issue (unless I missed it if so sorry for the repeat post). I can only get to 0.36v and my 2k trimpot is maxed out. The LED stays dim if not at all. I did notice when I first powered up the led was bright and the voltage was well over 5v so I let it discharge and tried again very slowly. Now it peaks at 0.36v. Any suggestions?. I let it discharge again and started over but ended up with the same results.
Thanks Pete...***** Little more reading through posts in here and found my answer. Worked like a charm.
Title: Re: Low Voltage reading on Mutiplex build
Post by: gtr2 on February 11, 2015, 11:42:27 PM
Glad you were able to find a solution :)
Josh
Post by: pogart on February 12, 2015, 02:26:38 AM
Thanks Josh, just waiting on a foot switch to arrive so I can test it out then it go's into a multi effect enclosure along with a Moodring reverb pedal. Ambient clouds await : )
Post by: gtr2 on February 12, 2015, 02:45:24 AM
Quote from: pogart on February 12, 2015, 02:26:38 AM
Sounds like a killer build!
Josh
Post by: pogart on February 12, 2015, 03:26:43 AM
I'll post some pics when I have it all ready to roll.
