Title mostly says it, I just don't know what it does. Is there a good replacement for it?
It does whatever is shown in the schematic that you didn't link us to!
If you are looking to find out what it does in general a datasheet is good place to start: http://www.mouser.com/ds/2/240/Littelfuse_TVS-Diode_P6KE-48586.pdf
I bet someone is trying to build a BluesBreaker/Morning Glory work-a-like.
Quote from: selfdestroyer on March 01, 2017, 03:36:06 PM
You pretty much guessed it. Haberdasher has a Morning Glory schematic up on his "Morning Wood" project. I've built it and a few of my own bluesbreaker style drives i've just never known what that diode does.
Quote from: midwayfair on February 28, 2017, 11:41:57 AM
My fault, here it is.
(http://i.imgur.com/7oQEqyy.png)
It's like a condom.... for your morning wood.... ;)
It's there for protection of the circuit in the event of reversed power supply polarity.
It's nothing like a condom. Under proper use, a condom will prevent the things it's supposed to without breaking. That diode will break the second you ask it to perform it's function.
Just leave it out.
Quote from: midwayfair on March 01, 2017, 06:53:56 PM
Just leave it out.
With all due respect did you look at the data sheet for that device?
With it's rating I sincerely doubt it will break in the first second of reverse voltage from a measly 9 volts.
Vbr min/max 114/126 @ 1 amp.
Quote from: galaxiex on March 01, 2017, 08:35:43 PM
Just leave it out.
I'll play. With all due respect, would you take a moment to explain to me why the reverse breakdown voltage of a non-zener diode is relevant to its longevity when
forward conducting 9V from a power supply delivering typically couple hundred to 2000 mA?
I will grant you it's probably better than a 1N4001, but if the diode doesn't die, the power supply still will.
EDIT: Also, I thought we were cracking jokes, not having a serious discussion about electronics. My bad.
Such respect!
