Took quite a while, but I finaly got this finished.
Tagboardeffects Boneyard, with dual volume, gain and EQ controls, switchable via 4pdt. EQ boards modular so to use a single pole on switch. After that a Thunderpuss boost.
Graphics are UV printed on an aluminum plate.
(http://i66.tinypic.com/29mar8z.jpg)
(http://i68.tinypic.com/ops2v6.jpg)
(http://i66.tinypic.com/28umbvb.jpg)
That wiring is so clean!
Says it all.
Hiwatt style wiring - awesome stuff.
You must have gone into a zen nirvana state to do that wireing.
Very sweet. Did anyone mention the wiring yet?!?
Make sure you block the exhaust port, otherwise it'll get clogged with X-wings.
Oh yeah, and the wiring, it's good! ;)
Quote from: mjg on May 06, 2018, 06:39:24 AM
crap... I knew I forgot something..
thank you ALL!
this was a pain in the ass ... but literaly hahaha ... so much time sitting in front of this.
remember the tom hanks green mile meme ? that was me when I finished :)
No words... really cool distortion pedal. 8)
I can see that Boneyard is slightly modified because the two EQs. Though the very clean wiring it's a bit hard to imagine the schematic.
Am I rude if I ask to you to share the layouts or something more about the EQ adding? :P
Thank you very much.
Quote from: JackSkellington on May 06, 2018, 09:39:44 AM
Not at all ... It´s nothing ultra fancy really.
4PDT's poles:
1-LED indicators
2-Hi / Crunch Switching ... just look up Brian´s prior Boneyard build docs.
3-EQ switching.. take the lead that goes to Volume 3 and conect to both EQ board's IN ... The OUTs of the EQ boards each go to the up and down positions of one of the poles. The center common of that pole is now the lead that goes to volume 3. There is a volume drop because of the extra load, so instead of using the last opamp as a boost , play with the value of R12 to even things out. Same reason I put an independent thunderpuss at the end of this "chain".
(http://i64.tinypic.com/qp137q.png)
4-Volume switching... it's basicaly the same thing that I did with the EQs, but instead of the center common from the EQs going to a single volume pot , I connected it to pin 3 of the two volume pots... this time the "outs" are your pin 2 of both pots, again going each to the up and down positions of another one of the poles. Now this pole's common is your Volume 2 connection (the one that goes to R11 in the above image).
Hope this helps.
A thing of beauty! Congrats!
Did you use solid core wire for this?
Quote from: Adam_MD on May 06, 2018, 01:14:31 PM
noup ... 22 AWG stranded.
I could stare at those pictures all day. 8)
Thanks for the instructions! ;)
You just learnt to me an import thing I still didn't get.:P
The two EQs should be a simple tonestack, and I guess, a Marshall style could be more appropriate. I see that trimpot, it is the Tone control, probably.
To recover the volume loss you advice to play with R12 - 22k, that should be control the gain of the last op amp stage.
But, could we try to decrease R11 - 47k? Or is right this the thing you advice not to do?
Quote from: JackSkellington on May 07, 2018, 08:45:09 AM
Yes. That works to. If you do a quick search for the schematic you'll see it sometimes at lower values.
Mine's at 4k7 actually.
And yes, the trimpot is the original tone control. You can leave a resistor for that to.
Amazing build!
