So I'm building a Sabertooth for a buddy of mine. I want to use Guitar PCB.com's 3pdt board to wire the switch. Does anyone have any experience with these boards(3pdt board) and how should I wire this up to the jacks as well?
I used one on a recent Big Muff build. It's handy and straightforward. Basically everything (except power) meets at the 3PDT board, and the documentation is helpful.
The board has a place for the LED and its resistor, and you can mount the LED directly on the board if the hole for the resistor is closer than an inch from the hole for the switch body. I used a predrilled enclosure with the holes 1.5" apart and it wouldn't reach, so I just aimed the LED toward the hole to illuminate a plug of hot glue and I'm satisfied.
If you're accustomed to soldering on etched boards, i's a good way to go, IMHO.
There's a wiring diagram on the page for that item (http://www.guitarpcb.com/apps/webstore/products/show/1343792) in the guitarpcb.com PCB Shop. Just click on it and it will display large enough to read.
Hey, I said something that made no sense:
Quote from: derevaun on October 10, 2011, 08:56:30 PM
What I meant to say was that you can mount the LED directly on the 3PDT board if the hole (in the enclosure)
for the LED is close to the hole for the switch body. I apologize for the error, and the responsible persons have been sacked, etc.
