Projects => General Questions => Topic started by: jimmybjj on July 22, 2010, 06:39:55 AM
I've been using the score and break method but I imagine some of you guys might have some elegant and not so elegant solutions ;D
I use one of the cutting attachments on my dremel and a vise. Nice clean cuts.
Bandsaw.
I have an old-school paper cutter that was my grandfather's; the kind they don't make anymore. The thing has a cutting arm on it like a lawn mower blade. It chops right through quickly & cleanly.
what do you guys think about using a chop saw? I can get a small one from harbor fright for $25. will it work well?
Not sure about the chop saw, but I use the rotary tool (dremel) from Harbor Freight and it works great. They have some kits for under $15 IIRC that includes cutting wheels.
i have a dremel as well but I am looking for a more efficient way of cutting straight with minimal cleaning followup.
How much do you want to spend, Jimmy?
I'm not super concerned with cost, it's more about the end product and the convenience. That being said I don't want to spend $300. I'd prefer to spend $30 but will consider anything up to about $200 especially if I can convince my wife I can use it for more than just pcbs ;D
Before I found that my heavy duty paper cutter worked so well for chopping copper clad I was actually looking at this (http://roundhacksawblades.com/) as a cheap alternative. Since inside corner cuts are such a herculean task with the cutter I may end up getting one anyway...
I have no idea how well it would work, but it'd be interesting to find out.
