Vfe zener cap combination. I can't see what's going on there on both the Tractor Beam and Bumble Bee. Is the cap just paralleled with the zener?
bump
It's a cheap voltage regulator. The combination is used to make reference and bias voltages for the JFETs. You wouldn't want to use a resistor divider there because the supply voltage can fluctuate with battery life or different DC supplies. The parallel cap it to reduce noise on the VREF.
Here's some info (https://www.electronics-tutorials.ws/diode/diode_7.html?nab=1&utm_referrer=https%3A%2F%2Fwww.google.com%2F) you want to read more about zoners as voltage regulators.
thank you sir.
