Based on Aion FX Thulcandra schematic, this is an adaptation of Xotic Sould Driven Allan Hinds signature drive. Aion changed the interal dip switches with a bass pot which makes a whole lotta sense.
Another great overdrive in the box... which one to play today...
(https://i.imgur.com/d0avP7Q.jpg)
(https://i.imgur.com/EAd7K40.jpg)
(https://i.imgur.com/OJrxPt5.jpg)
(https://i.imgur.com/GBhljMm.jpg)
(https://i.imgur.com/IKjFySy.jpg)
(https://media1.giphy.com/media/qPcX2mzk3NmjC/giphy.gif)
you've really got your style dialed in! I could identify your builds anytime (even without the top screw-technique).
lovely build as usual!
Cheers guys! Plyed it loud last night first time at band practise and liked it a lot. Great circuit, nice fat sounds and still defined.
Your builds are always amazing. I like that you added the relay bypass circuitry directly to the pcb. Is it pic based by the way? I guess so.
And what company do you use to print your pcbs? I've had good experiences with Seeed and of course Osh park.
Anyways, great build as usual!
Quote from: Boba7 on August 19, 2020, 07:57:44 AM
Cheers Boba! Yes relay bypass is PIC based, check out this great work and write up and it has the code as well:
https://www.coda-effects.com/2016/04/relay-bypass-conception-and-relay.html (https://www.coda-effects.com/2016/04/relay-bypass-conception-and-relay.html)
I have just relatively recently started designing pcbs again after doing it some years ago with Eagle. I'm now using Diptrace and I'm lovin' it, works a lot more intuitive and efficient for me.
PCBs I get done with
https://jlcpcb.com/ (https://jlcpcb.com/)
two batches so far and good experience, relatively fast turn around and boards seems just fine.
