...See, under a dollar :) It was a TIGHT squeeze but its all there including the charge pump. All of the resistors are SMD on the back of the board, pointed out by the pen. Their is gold fleck in the green that matches the brass knobs. The knobs are spent brass from 40cal rounds. I didn't have any knobs laying around that worked with the pedal and the brass was on the bench, so i had a aha moment. Fuzz = cops, cops shoot bullets, maybe its a stretch :) Finish is dual stage powdercoating including the lettering.
I have a couple of extra boards is anyone is interested in trying smd. $6 shipped
(https://lh5.googleusercontent.com/-xWkrknXiHzo/UAX6hx2YecI/AAAAAAAAI7g/bGpJMw4K8C4/s288/IMG_1143.JPG)(https://lh3.googleusercontent.com/-HEX55dJLox0/UAX6hNiFDKI/AAAAAAAAI7Y/kHTmgWNF0co/s288/IMG_1144.JPG)(https://lh5.googleusercontent.com/-F_3MUorfNAA/UAX6edQ-Z2I/AAAAAAAAI7Q/Vc5vCt7jh9I/s288/IMG_1145.JPG)(https://lh4.googleusercontent.com/-7DCQzmVRicI/UAX8rAtq6kI/AAAAAAAAI8M/HiRmR8JWhiw/s288/IMG_1147.JPG)
(https://lh3.googleusercontent.com/-keMMjWXwn_Q/UAX6mSL0-RI/AAAAAAAAI7s/qlAZKdADMsU/s288/IMG_1153.JPG)(https://lh3.googleusercontent.com/-x6X4YJMTfGM/UAX6wc2IbUI/AAAAAAAAI78/wYwDm17MDo8/s288/IMG_1155.JPG)(https://lh4.googleusercontent.com/-vLNic2k_92I/UAX6uNrmZaI/AAAAAAAAI70/cSnerrF8-Wk/s288/IMG_1154.JPG)(https://lh4.googleusercontent.com/-sMhYmjhgmok/UAX82fmdJgI/AAAAAAAAI9E/5LAAQP1GvTs/s288/IMG_1148.JPG)
Those knobs... are killer. ;)
Very cool all around. Those resistors are tiny.
Love the powdercoat work as well as the board!
Josh
Awesome all around.
The finish is indeed really spiffy. Is it just a powdercoat, or is there something else going on?
Fantastic. The entire thing.
I may have to use the bullet knob idea if you don't mind. What a great idea for 1590a builds.
Wow, looks perfect, everything gets nicely together.
I would take one of those board if you don't mind. 8)
Rej
Wow. I really dig the fit and finish. Superb indeed. :o
That is really slick! I'd also be interested in a board if you still have any.
-A.P.
Very nice! 8)
Thanks for the compliment guys.
Quote from: gtr2 on July 17, 2012, 06:31:00 PM
Thanks! The board came out good except that stupid batch number they put right over the fuzz face label, its hard to see from the pics i posted.
Quote from: midwayfair on July 17, 2012, 06:51:07 PM
thanks, just powdercoat. applied one coat, vinyl mask, applied second coat, remove mask. The process is all about timing and getting the masking off before it melts.
Quote from: GrindCustoms on July 17, 2012, 07:04:09 PM
Quote from: HappyCircuits on July 17, 2012, 09:27:31 PM
Sure, I'll pm you.
Damn :o That is cool!
I'm interested in a board! Are those standard 16 mm pots?
Quote from: jtn191 on July 18, 2012, 09:33:49 AM
Pm'd, yes they are standard 16mm pots. They are not board mounted. The holes are spaced for 9mm pots but I've never worked with 9mm pots so I'm not sure how that would work. The only pots I could find are the ones with tabs on the side. I don't know if those tabs need to grounded or what.
Quote from: jimmybjj on July 18, 2012, 09:49:16 AMThe holes are spaced for 9mm pots but I've never worked with 9mm pots so I'm not sure how that would work. The only pots I could find are the ones with tabs on the side. I don't know if those tabs need to grounded or what.
Smallbear has the kind with just three little PCB tabs. I think Das Musikding has them, too, at a reasonable price (E2.25) for everyone in Europe.
Quote from: midwayfair on July 18, 2012, 12:21:42 PM
Thanks, I couldn't find the ones I want on there. I was specifically looking for the ones with right angle pins so I could board mount them, the ones with straight pins don't help much in this context.
The bullet knobs are seriously cool. Where can I get some from (or did you mod some real bullets)
Quote from: Hangingmonkey on July 18, 2012, 02:07:09 PM
40cal brass, i made them :) Brass, sander, and hot glue.
Respect!
That's so rad. I'm diggin your finish!
I believe you sent me one of these but I didn't notice the SMD resistors. I'll have to find a place to source those cause I'm lovin it!
smd's are all on the back. the only smd resistors that tayda sells are the size that i used for this project, makes things a little easier.
I'd love to try one of these if you have any boards left, thanks!
C
Quote from: jimmybjj on August 31, 2012, 10:22:54 AM
Rad I'll check those out! Haven't done anything SMD in awhile..
