I built this L-Pad attenuator yesterday. $15 8ohm/100watt L-Pad, a few $2 switches, jacks, couple of caps, wire from a broken computer power supply and a $5 aluminum enclosure.
I installed a true bypass switch on-off-on bright switch with a 4.7uf cap on one side and a 10uf cap. Both non polarized caps. All 18 gauge stranded wire. I haven't drilled holes for the venting yet but from my tests with my amps I will not need a fan. I wouldn't use this with anything over 15-20 watts.
I haven't decided on a paint job or decals yet. Any ideas?
(http://img.tapatalk.com/d/13/01/09/a6yjuhyq.jpg)
(http://img.tapatalk.com/d/13/01/09/rutupy2a.jpg)
I plan to use this with my vht special 6 head for very quiet bedroom levels (kids right above sleeping)
Tested last night and today and it works good. Worked just as well with a tweaker15 to be able to hit its sweet spot and not irritate the neighbors.
With the s6 it was very nice. I will be able to practice with a real amp instead of sims (don't own amp with headphone out)
Thanks for allowing me to brag.
Rob
I got the same exact switches the other day! The switches look cool
wow very cool project, i bet a lot of people are gonna be interested in this one.
Is it your design? source on the attenuator?
Quote from: stecykmi on January 09, 2013, 05:35:41 AM.
Not my design at all. I just googled "DIY attenuator" and found this page.
http://guitarprojects.weebly.com/diy-attenuator.html
i added two different bright switch options. I guess that's a mod ;-)
Very cool, cheap and useful project.
L-pad is here
http://www.parts-express.com/pe/showdetl.cfm?partnumber=260-262
There are other l-pads on parts express as well. Don't pay attention to wattage. These are intended to be a tweeter control after a crossover, etc.
One guy used a stereo 8ohm 100 watt and wired to switchable to 8.or 16 ohms. I can't find that link at the moment.
The layout for Ken Fischer's Trainwreck Airbrake is floating around the internet.
very nice! I would love a DIY attenuator but I need 40 watts! Does anyone know how to build a Dr Z Brake Lite clone?
Quote from: Stomptown on January 09, 2013, 08:18:14 AM
I think the Dr Z Brake is based on the Airbrake (the one about alanp posted above).. You'll find it on the net. A little more complicated than the L-Pad attenuator, but it's supposed to sound better...
Hector
Nice build dude.
I would give it a nice hammertone finish.... but then I would say that wouldn't I :D
An amp attenuator has been on my 'to do' list for ages now. Thanks for posting the links/info!
Nice build. I whipped up a simple LPAD for my 5E3 Tweed and it works great. Used a 3.3uf cap on the attenuator to retain some treble in the signal.
I need something like this for my tweaker 15 head. Thanks for the links sirbw!
Try this:
http://ampgarage.com/forum/viewtopic.php?t=2402&postdays=0&postorder=asc&start=0
Quote from: Haberdasher on January 09, 2013, 01:19:39 PM
It works fantastic with my tweaker 15.
Just remember that you still have to make sure you have a speaker plugged into the attenuator so you don't blow your amp transformer.
Quote from: raulduke on January 09, 2013, 09:57:27 AM
Nice build dude.
Thanks for the complement. I think I will do hammertone copper finish with a lawyer clear coat to make it alligator like crazy. Nah, that will take 4 weeks to cure out.
This looks good man! I recently built a DrZ AirBrake for my Maz18, best decision ever, great live to give you more power tube saturation at lower volumes, and the bedroom playing too!
George
Quote from: hammerheadmusicman on January 09, 2013, 09:04:25 PM
George
Would you mind supplying any links etc for the Zbrake build? Thanks
of course not..
http://www.andyharrison.net/files/AirbrakeLayout.jpg
that's verified too, by me! mouser part numbers too :)
be careful when you order though, as from mouser UK, the nig resistor didnt come with the clips that you set to certain ohms.. so i had to send for them seperate and pay postage!
George
Quote from: hammerheadmusicman on January 09, 2013, 10:06:25 PM
of course not..
George
THANK YOU!!!!!!!!!
You're very welcome, glad i can finally be of some service! ;)
i think the parts inc all hardware cost me about £60-70ish from mouser.. a hefty saving on almost £300!!
it is great attenuator. Transparent. Sounds greta with my Z, just like having a post amp volume knob, unlike the old marshall ones which are tone destroyers apparently!
of course not..
George
gracias amigo !
One thing that the Amp Garage thread mentions about the big power resistor that has taps on it -- you need to LIGHTLY sand the exposed coil, to make sure that the taps make contact. (Apparently there tends to be some coating over it.)
I added an L-pad attenuator to a Valve Jr combo quite some time back. I didn't bother with all that fancy "additional cap" stuff like you guys. ;D
I put mine in the amp chassis (on the back) to make it more like my Univalve. It works quite well, but the taper is somewhat lopsided.
I should also add that I was modding a V1 Valve Jr, which only had a 4-ohm output. So I added a 4-ohm resistor in parallel to bring it down to 8 ohms. It was a monster 20W resistor, by the way. No sense in taking chances. ;D
Here's the info on it:
http://www.forrestwhitesides.com/node/81
(http://www.forrestwhitesides.com/files/up/img/layouts/attenuator_wiring_sm.png)
Here is the amp (which I sold):
(http://i257.photobucket.com/albums/hh218/reverse_engineer/VJ_rebuild/vjmod3.jpg)
(http://i257.photobucket.com/albums/hh218/reverse_engineer/VJ_rebuild/vjmod5.jpg)
This is a great project! I wonder if the switchable bright cap thing would work with my Weber Mini Mass? I never use it because it sounds like a wet blanket over the speakers.
I built an Airbrake a couple of years ago after reading a ton about attenuators. It works well, and was fairly simple to build. Not particularly cheap though, and I honestly decided I like to use pedals and the master volume better.
I just find that it allows me to crank my maz a little more on stage, it wasn't too cheap, but was less t Han a third of the retail!
I would rather build the brake lite. It is good up to 45 or 50 watts and its a bit cheaper. Anyone have any info on how to build one?
No sorry, the airbrake is good up to 100 watts. i think parts would be a lot cheaper on your side of the pond though!
George
do you have a link to the DrZ project you used?
I did post it earlier in this thread, but here it is again :)
that's all i had..
Quote from: hammerheadmusicman on January 12, 2013, 11:33:19 PM
that's all i had..
whoops. i missed it earlier. thanks!
No worries dude, it's a useful piece of kit! Use min all the time!
