The Mod (3in1)
Started by GrindCustoms, December 01, 2013, 11:12:50 AM
GrindCustoms
Thanks for all the comments guys, will always be appreciated.
Just throwing out an idea like that, couple of us guys here builds multis on a steady basis. Maybe we could collaborate and make some sort of tutorial?
Also, i have a little reason to be festive with this one, after filling my build spread sheet, this is my 600th completed pedal....Woohooo!!
And since i live on the dark side of the moon, behold for the 666th, pure evil it will be!
No problems with bleedover? Im surprised you have no heterodyning with the two clocks in there.
Good work!  ;)
With the LT1054.... did you clip off the lead on the chip as suggested in the build docs?
GrindCustoms
Quote from: Govmnt_Lacky on December 03, 2013, 12:37:10 AM
Good work!  ;)
No clock problem at all, it's super clean.
I took out the pin1 of the socket as per the build doc.
What i've found with most effect that uses clock and voltage multiplier other than getting the right ones to minimize the chances of having operation noise, is buying good caps, all the caps going to ground or coupling, if you use so so quality stuff ie. Tayda, chances of having problems are really high. I always use Nichicon and ELNA Audio Grade, not really more expansive than the other and in the end, you build with confidence.
ncdb07
Quote from: GrindCustoms on December 02, 2013, 10:53:08 PM
Congrats on your 600th pedal! Wow! Thats a lot! A tutorial on connecting multiple circuits would be awesome!
Thanks!
ncdb07
Daniel
ncdb07
Daniel
