Space Saving
Started by GrindCustoms, May 14, 2014, 10:05:34 AM
Quote from: juansolo on May 15, 2014, 09:41:45 AM
8)
Mini-footswitch FTW. I've eliminated the FS completely for the Twang King as I don't need it. Instead I made this to turn the trem on and off:
Brilliant! I LOVE that. Not sure if you stole or found that, but it's inspirational. I'll probably do something similar for my Vibro Champ.
GrindCustoms
Pretty sure you could get rich at selling those John, since it's a mechanical concept, you can probably patent it. ;)
That truly is supremely clever! I was going to comment on it earlier but I thought, 'maybe that's something everyone else knows about. I'll look dumb for not knowing about this routine thing.'  :)
8)
Yep, this rules.
Quote from: jkokura on May 15, 2014, 10:09:42 PM
8)
Had a spare plug that's been in my toolbox for ages and sub-mini toggle that was ordered by mistake once. Then had a light bulb moment :)
It's a very tiny PCB mount sub-mini toggle and I still had to file the edges. I cut down the wire gripper inside so it sat in/on that, cut the strain relief off the plug and put a big washer on the top of the switch. When it's screwed together it is totally solid.
