Switches that fit under a pot mounted board?
Started by peAk, June 25, 2014, 04:54:28 PM
One thing I run into sometimes is that I want to have a switch in a certain spot on an enclosure but if I have a pot that's mounted to the board, it's too shallow to allow for a switch.
Are there any switches that are shallow/short lugs?
upthepunxxx
Like a footswitch or a toggle? Lawrence over at Bitcheslovemyswitches sells these guys http://www.bitcheslovemyswitches.com/#!/~/product/category=5027572&id=33283018
But I'm not sure thats what you are looking for, or you may have already tried these?
Wake up and smell the noise!!
gtangas
Hi
Yes there are a mini mini :-D spst switches... Not the red that you can find on tayda but a blue ones that are smaller
And you can cut some of the length of the pins and solder near to the switch enclosure
Another option is to raise the PCB board using standoffs...
upthepunxxx
Oh yea sorry, I meant to post a link to sub mini toggles as well. Gracias!
Quote from: gtangas on June 25, 2014, 06:13:23 PM
Hi
Recently I ran in to this and just had to bend the solder lugs down and cover them with insulation
