Firebomb (why do I do this to myself?)
Started by pandadandan, April 21, 2011, 05:19:34 PM
pandadandan
Had some spare solid-core mil-spec wire kicking around, so decided to do some idiotic wiring.  Utterly unnecessary.  It does add a level of excitement when you've wired it up in a manner which makes it impossible to easily take apart, yet you've never bothered to test it before putting it in the box.
Thankfully, it worked first time.  Otherwise I'd have thrown it out of the window in utter disgust.
Here be the wee beastie:
And the money shot:
It's so artistic!  Like a cubist painting in there!
night-B
jimmybjj
Pcbs no longer available
mattpoole
such control with the wire, i am jealous. :)
pandadandan
Thanks!
It was an exercise in pointlessness, though.  The wire is amazing to work with, though.  Solid-core is great, but this stuff is awesome.  The sleeving is teflon, so I could solder it on the trace side without any jacket shrinkage/melting like I get with my usual stranded hookup wire.  OTOH, if you make a mistake with your bends, straightening them out and rebending really takes its toll on the wire.
I'll try to avoid doing this style again, but I invariably will end up doing the same.  Maybe I should get drunk again like I did with my Kokbox build.   ;D
cjkbug
I got myself a couple big spools of that wire. it's great to work with. super easy to solder
mattpoole
Quote from: pandadandan on April 22, 2011, 12:31:31 AM
i have some of that stuff, it is great quality. the teflon is super slick (quite literally), and a little hard to handle when stripping IMO. the stuff i have is Mil Spec Teflon stranded wire in 22 AWG.
JeffdaMaori
Great origami exercise! Really great work!  ;D
bigmufffuzzwizz
Woah man  :o !! I see you've got some free time!
jtn191
