Yeah... it's official
Started by Willybomb, September 06, 2014, 10:49:16 AM
I use the following without issues:
-Craftsman 12" Drill Press with Laser and LED Light
http://www.sears.com/craftsman-12inch-drill-press-with-laser-and-led/p-00934985000P?prdNo=1&blockNo=1&blockType=G1
The Laser track can be pretty useless since the diameter of the stepper drill bit will block the laser some. I also set it to the fastest belt drive setting. If you drill on slower settings I found that the enclosure will heat up to quick and cause the drill bit to bind/catch.
-4" Drill Press Vise
http://www.harborfreight.com/4-inch-jaw-capacity-drill-press-vise-30999.html
Workes perfectly for my needs and it was cheap. Win Win
-Cheap step drill bit
http://www.harborfreight.com/3-piece-titanium-nitride-coated-high-speed-steel-step-drills-91616.html
I buy a new set 2 times a year it seems and they work just fine. I use them just on aluminum to help them last longer.
-Automatic center punch
http://www.harborfreight.com/automatic-center-punch-with-brass-handle-62141.html
I will sharpen it with a file a few times a year. I only use it on aluminum so it will last longer.
I use paper templates made in Photoshop to scale. I print them and tape them to the enclosure and center punch them. I too over drill a tiny bit to help get a better fit with pots.
