Rangemaster Build, OC44 Yellow Jacket
Started by PigeonFX, March 22, 2015, 02:19:03 AM
Jebus
PigeonFX
Quote from: billstein on March 22, 2015, 06:05:00 AM
Really nice! Can I ask what that silver thing is that says 5000J?
Yes, these are Polystyrene (Styroflex) Capacitors (5000 denotes is 5000pF/5nF/0.005uF), they have fallen a little out of favour as it's hard to find them in a good range of values, but I personally really like using them for input/output caps as they have such low leakage, low dielectric absorption and low distortion, so used a 5nF for the input, and 8,2nF for the output on this build.
You only really see them in audio applications now days.
I'm PigeonFX - www.pigeonfx.com
Quote from: PigeonFX on March 23, 2015, 12:47:33 AM
Good source for polystyrenes in NA is Just Radios, have  a high minimum order but a wide range of values , 10pf - 10,000pf, big selection of CC resistors and i've been using their various high voltage coupling caps in my guitar amp builds and been completely happy with the results.
http://www.justradios.com/cart.html
Great looking build, you've really nailed the original's look.
PigeonFX
Sehr nette Arbeit. Der einzige Sachevermißte ist einige Rostpunkte. Es würde ein trügerischer Klon sein. :o
Signatures are displayed at the bottom of each post or personal message. BBCode and smileys may be used in your signature.
