switching question
Started by adam_bz, August 20, 2016, 11:58:52 AM
adam_bz
Hi.
its probably really simple, but I cant get my head around this for some reason - hopefully someone can help.
Looking at adding a second 3pdt to an enclosure. The first will be the main on and off bypass, the second 3pdt to add in a second effect such as an octave to a fuzz but if you click stomp one it goes directly to off for all rather than just off for effect one.
Hope that makes sense.
Thanks
Stomp one the effect in and out will go to stomp two's main in and out.
ok here we go:
*) first main bypass is wired as usual. In/Out Jacks are wired to this stomp
*) However, the effect out (pcb out) of the first pcb goes directly to the second bypass switch
*) second switch is also wired as usual.
*) second switch out (the one usually connected to the out jack) is wired to the free position on switch 1 (the lug generally wired to the pcb out.
