Current Lover C1 value
Started by taeagan, October 02, 2016, 05:20:00 PM
taeagan
C1 in the Current Lover is listed as 39n. It's the filter cap right at the input. This can't be a critical value, right? Can I sub in 22n or 47n? Thanks.
You can definitely try a different value in there, it may change the sound slightly from the original.  I haven't built this so can't comment from experience.
For almost the entire run of the original Electric Mistress, the value was .1uf. So there aren't going to be any earth-changing effects by going higher than 39nf; you might even prefer the increased bass content and volume.
I like to use essential oils to relax.
Which ones?
Well, chloroform; quite effective, that.
